Freestream boundary condition confusion - k-epsilon
Old   July 11, 2014, 06:13
Default Freestream boundary condition confusion - k-epsilon
E.B
Jalued is on a distinguished road
Hi all,
I have only been working with OpenFoam for the past few days but have worked with FLUENT before. The simulation is of 2D water flow past three pillars in a freestream with an absolute pressure of 50.27bar
I am confused what free stream boundary conditions I should be using, preferably for use with k-epsilon
My current BC are
inlet (note, internalField is (1 0 0))
U: type fixedValue;
freestreamValue $internalField;
P: type zeroGradient;
k: type fixedValue;
value uniform 18.375;
epsilon: type fixedValue;
value uniform 3.6975;
outlet
U: type zeroGradient;
P: type fixedValue;
value $internalField (set as 50.27e5)
k: type zeroGradient;
epsilon: type zeroGradient;
symmetry 1,2,3,4
type symmetryPlane for all
wall 1,2,3
U: type fixedValue;
value uniform (0 0 0);
I have been trying to adjust tutorials to fit my setup, but so far nothing is working. Please be as brutal and honest as necessary, I'm sure all of this is complete garbage... but I just want to start understanding where I'm going wrong.
Thanks,
Ed
Edit: the error message that I get now is:
PHP Code:
Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
with no other error messages in the log file:
PHP Code:
Create time
Create mesh
for time 0
Reading field p
Reading field U
Reading
/calculating face flux field phi
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu             0.09;
C1              1.44;
C2              1.92;
C3              -0.33;
sigmak          1;
sigmaEps        1.44;
Prt             1;
No finite volume options present
SIMPLE
convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field k     tolerance 0.001
Starting time loop
Time
0.5
File Type: jpg Screenshot from 2014-07-11 11:08:29.jpg (82.0 KB, 63 views)
File Type: jpg Screenshot from 2014-07-11 11:10:26.jpg (65.5 KB, 34 views)
Jalued is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
Radiation interface hinca CFX 15 January 26, 2014 17:11
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
