[swak4Foam] groovyBC and access to alpha field of other patch
Like Tree4Likes
  • 2 Post By Tobi
  • 2 Post By gschaider
Old   August 19, 2014, 04:31
Default groovyBC and access to alpha field of other patch
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I want to get access from alpha field from patch1 to use it in patch2.
The problem is that my alpha field does not exist?
type     groovyBC;
variables "alphaFromPatch1{patch1}=alpha.liquid;";
valueExpression "alphaFromPatch1";
Additionally I tried with:
  • alpha
  • alpha1
  • alpha2
  • alpha.liquid
  • alpha.air
But always I get an error that this variable does not exist or is of wrong type.
Does anyone have some idea?
Additionall question:
Is it possible to get velocity field U from patch1 and use it for patch2 not in an averaged value?
nimasam and Bana like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 21, 2014, 19:05
Assistant Moderator
Bernhard Gschaider
Originally Posted by Tobi View Post
Hi all,
type     groovyBC;
  • alpha
  • alpha1
  • alpha2
  • alpha.liquid
  • alpha.air
alpha.liquid won't help at all. swak does not consider the dot to be a valid part of a field name (it is a bit like C++ here) because it needs it to access components. To access fields with "illegal" characters in the name "aliases" have been added to swak some time ago (have a look at the forum, the README or the incomplete reference guide).
To find out under which name this field is known you'd have to consult the sources. Or there is a function object listRegisteredObjects that lists all objects currently registered in the registry. One of these objects should be your alpha
Only if the patches are declared as mapped in the boundary-file
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 1, 2014, 16:09
Tobi's Avatar
Tobias Holzmann
Dear Bernhard,
if I use mapped patch type I also get a interpolated velocity field:
smoothSolver:  Solving for alpha.liquid, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0.088941  Min(alpha1) = 0  Max(alpha1) = 1
MULES: Correcting alpha.liquid
swak4Foam: Setting default mesh
swak4Foam: Allocating new repository for sampledGlobalVariables
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 4.41011e-06, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 5.89124e-06, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.00848398, No Iterations 5
--> FOAM Warning :
    From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
    in file ExpressionResult/ExpressionResultI.H at line 332
    The minimum value (-0.325913 -0.0248373 0) and the maximum (0.135614 1.34743 0) differ. I will use the average (-0.0315278 0.429949 0)
time step continuity errors : sum local = 1.2011e-06, global = -7.49768e-07, cumulative = -7.49768e-07
GAMG:  Solving for p_rgh, Initial residual = 0.00236714, Final residual = 7.34319e-09, No Iterations 31
--> FOAM Warning :
    The minimum value (-0.135501 0.000179205 0) and the maximum (0.101674 0.436928 0) differ. I will use the average (-0.0170261 0.171489 0)
time step continuity errors : sum local = 4.0578e-11, global = 3.5819e-11, cumulative = -7.49732e-07
DILUPBiCG:  Solving for epsilon, Initial residual = 0.0161811, Final residual = 1.53934e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 2.04556e-06, No Iterations 3
ExecutionTime = 0.36 s  ClockTime = 1 s
The BC is like that:
    internalFacesForGroovyBC_master
        type            groovyBC;
        value           uniform (0 0 0);
        variables       "x1=5;y1=6;x2=30;y2=0;function1=(y2-y1)/(x2-x1)*(time()-x1)+y1;x3=35;y3=0;x4=60;y4=4;function2=(y4-y3)/(x4-x3)*(time()-x3)+y3;";
        valueExpression "vector(0,0,0)";
        gradientExpression "vector(0,0,0)";
        fractionExpression "(time() < 5) ? 0 : 1";
    internalFacesForGroovyBC_slave
        type            groovyBC;
        variables       "velo{internalFacesForGroovyBC_master}=U;";
        valueExpression "velo";
Do you have some hints?
Keep foaming,
Tobias Holzmann
Old   September 1, 2014, 16:55
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
--> FOAM Warning :
--> FOAM Warning :
        type            groovyBC;
        type            groovyBC;
Use mapped(U) instead of the remote patch syntax. There are 2 or three examples in Examples/test (the cases with "mapped" in the name)
Tobi and the_ichthyologist like this.
Old   September 2, 2014, 04:04
Tobi's Avatar
Tobias Holzmann
Hi Bernhard,
many thanks to you. Mapping the velocity field U is working without problems now. I think it knows which patch to map out of the boundary file (sampleRegion or coupleGroup). I will have a look at your mentioned "aliases" to get the alpha field for the further step now.
Thank you again.
Keep foaming,
Tobias Holzmann
[swak4Foam] codedMixed instead of groovyBC GerHan OpenFOAM Community Contributions 3 February 20, 2019 11:08
[swak4Foam] access field variables in groovyBC mehtab OpenFOAM Community Contributions 11 February 4, 2019 12:08
[swak4Foam] groovyBC and access to fields of other Regions ancolli OpenFOAM Community Contributions 0 July 29, 2017 08:41
[swak4Foam] whats the trick to access to second layer of patch neighbors in groovyBC? immortality OpenFOAM Community Contributions 6 July 9, 2013 12:01
[swak4Foam] Can groovyBC access dimensionedScalar? argonaut OpenFOAM Community Contributions 1 May 24, 2012 09:04
