[swak4Foam] GroovyBC installtion help
Old   August 24, 2014, 20:40
Default GroovyBC installtion help
Delstat
pradeepramesh is on a distinguished road
Hi
I am referring GroovyBC installation from:
http://openfoamwiki.net/index.php/Contrib/groovyBC
I have downloaded groovyBC files at location:
@ OpenFOAM/user/groovyBC
wmake libso
I am facing error to install groovyBC (Error file is attached). Would be great to hear your views.
Thank you,
Pradeep
pradeepramesh is offline   Reply With Quote
Old   August 25, 2014, 10:55
blacksquirrel is on a distinguished road
Hi Pradeep,
the error says, that it can't find bison. Is bison installed on your system?
check with
bison -V
If you don't have bison, do:
sudo apt-get install bison
(or any other package installation program)
After you installed bison, try to compile groovyBC again.
Regards
Squirrel
blacksquirrel is offline   Reply With Quote
Old   August 25, 2014, 17:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by blacksquirrel View Post
Hi Pradeep,
check with
bison -V
Regards
Squirrel
Spot-on diagnosis.
Never mind: he seems to have found the solution by himself (4h later he posted a more detailed question on groovyBC).
pradeepramesh: it would be nice if you find the solution by yourself to tell others so that they don't waste their time. Just answer you own question with something like "Solved it myself. Did not install bison".
Ah. And by the way: don't post screenshots from error messages. They are not searchable. So nobody will find the problem (and therefor the solution) when using "Search"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
