ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary
Old   October 11, 2016, 08:47
Default ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary
Sing
Struggle_Achieve is on a distinguished road
Hello Everyone I am using a shell script to run my case.
In that I have used the changeDictionary command to populate the boundary conditions in ZERO folder.
But while running using script I get this error:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : changeDictionary
Date   : Oct 11 2016
Time   : 18:05:14
Host   : "hpc4"
PID    : 22709
Case   : /home/1016914/auto_case_home_final/Cases/case1_dp_1500_dt_100_dh_388_dw_1000_wt_100_wh_485_depIn_300_hPad_210_depPad_150_T_1873_MFR_16.665/meshANDsimulation
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'value' on line 197 and ending at line 197"
file: /home/1016914/auto_case_home_final/Cases/case1_dp_1500_dt_100_dh_388_dw_1000_wt_100_wh_485_depIn_300_hPad_210_depPad_150_T_1873_MFR_16.665/meshANDsimulation/system/changeDictionaryDict at line 197.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
But when I am manually running the changeDictionary command then its working.
I am confused about the reason for the error.
My changeDictionaryDict file's code is as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      changeDictionaryDict;
dictionaryReplacement
    U
        internalField   uniform (0 0 0);
        boundaryField
            "(topsur|botsur|twall|dam|weir)"
                type            fixedValue;
                value           uniform (0 0 0);
       "inlet"
          type            flowRateInletVelocity;
         rhoInlet    7020;
                massFlowRate    constant 16.665;
       "outlet"
        type             pressureInletOutletVelocity;
       "symmetry"
        type         symmetry;
    T
        internalField   uniform 1873;
        boundaryField
            "topsur"
            type            fixedGradient;
              gradient        uniform -365.85;
        "(botsur|twall|dam|weir)"
                 type            fixedGradient;
               gradient        uniform -75.61;
            "inlet"
        type            fixedValue;
               value           uniform 1873;
        "outlet"
        type            zeroGradient;
        "symmetry"
        type         symmetry;
    epsilon
        internalField   uniform 1.95e-04;
        boundaryField
            type            epsilonWallFunction;
               value           uniform 1.95e-04;
       "inlet"
          type        fixedValue;
       "outlet"
            type        inletOutlet;
        inletValue    uniform 1.95e-04;
       "symmetry"
        type         symmetry;
    k
        internalField   uniform 2.7e-04;
        boundaryField
            type            kqRWallFunction;
            value           uniform 2.7e-04;
       "inlet"
          type        fixedValue;
       "outlet"
            type        inletOutlet;
        inletValue    uniform 2.7e-04;
       "symmetry"
        type         symmetry;
    p_rgh
        internalField   uniform 0;
        boundaryField
           "(topsur|botsur|twall|dam|weir|inlet)"
                type            fixedFluxPressure;
               rho              rhok;
            value           uniform 0;
       "outlet"
        type         outletInlet;
        rho        rhok;
        outletValue    uniform 0;
        value        uniform 0;
       "symmetry"
        type         symmetry;
    p
        boundaryField
                type            calculated;
                value           uniform 0;
     "symmetry"
        type         symmetry;
    alphat
        boundaryField
            type            alphatJayatillekeWallFunction;
               Prt             0.85;
            value           uniform 0;
       "inlet"
          type        calculated;
        value        uniform 0;
       "outlet"
            type        calculated;
        value        uniform 0;
       "symmetry"
        type         symmetry;
    nut
        boundaryField
            type            nutkWallFunction;
            value           uniform 0;
       "inlet"
          type        calculated;
        value        uniform 0;
       "outlet"
            type        calculated;
        value        uniform 0;
       "symmetry"
        type         symmetry;
Any help would be greatly appreciated.
Thanks and regards,
Singh.
Struggle_Achieve is offline   Reply With Quote
Old   October 11, 2016, 08:50
Sing
When I am manually running changeDictionary then this is the output at the terminal.
[1016914@hpc4 meshANDsimulation]$ changeDictionary
Date   : Oct 11 2016
Time   : 18:05:41
Host   : "hpc4"
PID    : 22852
nProcs : 1
Create time
Read dictionary changeDictionaryDict with replacements for dictionaries
8
U
T
epsilon
k
p_rgh
p
alphat
nut
Reading polyMesh/boundary file to extract patch names
Loaded dictionary boundary with entries
8
inlet
outlet
topsur
botsur
twall
dam
weir
symmetry
Extracted patch groups:
    group symmetry with patches 1(symmetry)
    group wall with patches
5
topsur
botsur
twall
dam
weir
Replacing entries in dictionary U
Loading dictionary U
Loaded dictionary U with entries
3
dimensions
internalField
boundaryField
Merging entries from
2
internalField
boundaryField
Writing modified fieldDict U
Replacing entries in dictionary T
Loading dictionary T
Loaded dictionary T with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict T
Replacing entries in dictionary epsilon
Loading dictionary epsilon
Loaded dictionary epsilon with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict epsilon
Replacing entries in dictionary k
Loading dictionary k
Loaded dictionary k with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict k
Replacing entries in dictionary p_rgh
Loading dictionary p_rgh
Loaded dictionary p_rgh with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict p_rgh
Loaded dictionary p with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Replacing entries in dictionary alphat
Loading dictionary alphat
Loaded dictionary alphat with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict alphat
Replacing entries in dictionary nut
Loading dictionary nut
Loaded dictionary nut with entries
3
dimensions
internalField
boundaryField
2
internalField
boundaryField
Writing modified fieldDict nut
End
Old   December 20, 2017, 03:58
Sing
It was due to the exceptionally large folder name. As renaming the folder solved the problem
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
