decomposePar crash against oscillatingInletACMI2D
Old   December 1, 2014, 23:29
Default decomposePar crash against oscillatingInletACMI2D
s_shimz
s_shimz is on a distinguished road
Hi foamers,
I decomposed the tutorial mesh of oscillatingInletACMI2D with 4 domains, but the following error message was shown.
Does not the decomposePar still correspond to new feature cyclicACMI?
Somebody helps me.
| \\ / O peration | Version: 2.3.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.x-590d57f32fed
Exec : decomposePar
Date : Dec 02 2014
Time : 13:22:50
Host : "sv40432"
PID : 17101
Case : /work3/u15002/OpenFOAM/u15002-2.3.x/tutorials/oscillatingInletACMI2D
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Decomposing mesh region0
Create mesh
AMI: Creating addressing and weights between 40 source faces and 96 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1, 1
AMI: Patch target sum(weights) min/max/average = 0, 1, 0.4
Calculating distribution of cells
Selecting decompositionMethod scotch
Finished decomposition in 0.03 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::cyclicACMIPolyPatch::setNeighbourFaceAreas() const in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libmeshTools.so"
#4 Foam::cyclicACMIPolyPatch::resetAMI(Foam::AMIInter polation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::interpolationMethod const&) const in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libmeshTools.so"
#5 Foam::cyclicACMIPolyPatch::initGeometry(Foam::Pstr eamBuffers&) in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libmeshTools.so"
#6 Foam:olyBoundaryMesh::calcGeometry() in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libOpenFOAM.so"
#7 Foam:olyMesh::addPatches(Foam::List<Foam:olyPa tch*> const&, bool) in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/lib/libOpenFOAM.so"
#8 Foam::domainDecomposition::writeDecomposition(bool ) in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/bin/decomposePar"
#9 main in "/home/u15002/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc48DPOpt/bin/decomposePar"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
s_shimz is offline   Reply With Quote
Old   January 21, 2015, 12:20
Francois
Fransje will become famous soon enough
Hi there,
See this post.
Kind regards,
Francois.
Fransje is offline   Reply With Quote
Old   January 22, 2015, 02:28
s_shimz
Thank you for your reply, but when we use both decomposePar and pimpleDyMFoam, we must iteratively change the code of cyclicACMIPolyPatch.C... It is not supposed to be the thorough solution.
However, I'm anoyed by the problem, stopping my job, but this method can be a temporal solution. Thank you for giving a nice solution.
Originally Posted by Fransje View Post
Hi there,
See this post.
Kind regards,
Francois.
decomposepar cyclicacmi
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 08:57
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
decomposePar: can use this decomposition method only for the whole mesh aloeven OpenFOAM Bugs 0 March 16, 2011 10:15
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
