how to calculate the porosity flow rate?
Old   December 15, 2014, 14:06
Default how to calculate the porosity flow rate?
Heremus is on a distinguished road
Hello I need fast help and unfortunatly i found nothing in my search (thats is unusual ). My solution doesn't work.
My case is incompressible and isothermal. I have a porous zone where I want to calculate the porosity more or less so that I get a certain flowspeed in that area.
I took the equation from the Darcy Forchheimer header file.
S = - (mu*d + 0.5*rho*U²*f)
I assumed that S is a force and flow only flows in one direction so I took the U into the brackets.
So I thought about setting d to zero and using a bernulli equation to substitute S.
S = - deltaP * A =- 0.5*rho*(U²-U²_after)*A
After substituting this I relocated it to f:
f = A*(1-U²_after/U²)
But it doesn't work. The values are to low. So what all do I wrong.
Thanks for every help!
Heremus is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
[OpenFOAM] calculate flow rate (artery geometry) vitorspadetoventurin ParaView 3 January 2, 2015 07:44
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
how to calculate mass flow rate /simpleFoam greel OpenFOAM Post-Processing 15 November 16, 2012 00:16
Calculate the entering flow rate in each cell bephi Fluent UDF and Scheme Programming 2 May 30, 2012 11:11
