March 31, 2015, 04:58 |
Actuator Disk/ Depressure Source
Francesco
Rep Power: 11 |
i need to simulate the effect of a boundary layer ingestion. So i need to simulate the suction effect of the engine and the jet velocity, but i don't care about the engine performance. I "simply" need to tell that there is a suction area in the intake and a blowing area in the exhaust. I look at both fvOptions and cerateBaffle, but i did not understand how work. I have to create the geometry of the disk wall in the stl or i can simply define it in the fvOption/crateBaffel dict? Wich ones of the two method is better for my purpose? |
March 31, 2015, 06:55 |
Icaro A. Accordi
Rep Power: 15 |
Use fixedJumpAMI or fixedJump.
March 31, 2015, 08:23 |
Francesco
Rep Power: 11 |
Can you tell me how use it?
March 31, 2015, 08:52 |
Icaro A. Accordi
Rep Power: 15 |
Use it in the high pressure patch p dictionay:
highPressureSide { type fixedJumpAMI;// or fixedJump for conforrmal cyclic patches patchType cyclic; jump uniform 10;// (pressure/rho) jump for incompressible } And it for the another patch (low pressure) in p dictionary: lowPressureSide { type cyclicAMI;// or just cyclic for conforrmal cyclic patches } All other variables (e.g.U, k, epsilon, omega, etc) are setting in both patches as : highPressureSide { type cyclicAMI;// or just cyclic for conforrmal cyclic patches } lowPressureSide { type cyclicAMI;// or just cyclic for conforrmal cyclic patches } |
March 31, 2015, 10:07 |
Francesco
Rep Power: 11 |
I'm more noob than you think...
I only know how to run a simpleFoam ofa wing or other static and simple body. I took an stl file and put in SHM.. How can i introduce the "fan" I have to create the fan surface in the stl file or it could be assigned with some dictionary? I don't know if you understand me, my english level is low.. |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
