Newbie Pre-Processing problem with pimpleFoam: Courant Number mean: 3.33586e+29 |
May 10, 2015, 11:26 |
#1 | |
Rep Power: 10 |
Hey, im extremly new to OpenFoam and can't find the solution to this problem:
I am using version 2.31, and i am trying to simulate a turbulent flow created by a cylinder hitting a naca0012-airfoil with pimpleFoam and the classical k-epsilon-modell. i tried different k's, epsilons, p's and U's etc. and i also changed smoother-tolerances and switched turbulence on and off. |
May 10, 2015, 11:28 |
Rep Power: 10 |
and maybe these files could be also helpful? :-D
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
