July 30, 2015, 15:37 |
Fan Pressure BC
daniel
Rep Power: 10 |
Hello
I was hoping some one can help me out, i am trying to simulate a fan in a fluid domain see picture. I have looked at the TjunctionFan example and as i understand it the fan has to be defined as a cyclic boundary condition. In my case I am importing a mesh from fluent, does the createbaffles and toposet still apply in this case. And if so how to i apply it to my model i have both ends of the fan defined as a patch currently. |
July 31, 2015, 12:39 |
#2 | |
daniel
Rep Power: 10 |
Ok so i am trying to make this work i have used Helyx for the initial set up, I then attempted to add in the fanPressure BC but i get the following error
August 26, 2015, 09:03 |
Daniel P. Combest
I just noticed this one out there but I'm sure it's answered already. the fanPressure BC is actually derived from patch and not from cyclic. The error that you are seeing basically states that your base type defined in constant/polyMesh/boundary for jtf_inlet needs to be changed from cyclic to type patch. Then you can setup the fanPressure bc.
Pressure drop using Fan type BC | Alexis Sack | OpenFOAM Running, Solving & CFD | 2 | September 22, 2014 09:18 |
Pressure condition in fan simulation | ayothicfd | Main CFD Forum | 0 | April 16, 2012 22:30 |
Negative Pressure in fan modelling | Jenny | CFX | 3 | September 30, 2007 08:47 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
