Apply heat flux boundary condition
Old   August 2, 2015, 00:09
Default Apply heat flux boundary condition
nasir musa yakubu
esujby is on a distinguished road
I am completely new to OpenFOAM and would really appreciate any input or guidance you can provide on how to set up a case for the problem-discussed bellow.
I have conducted an optical ray tracing analysis on software called tonatiuh and did the post processing on Mathematica. The result of this procedure is a flux distribution profile at the aperture of a solar receiver. The 3D flux distribution profile can be exported in STL and VTK file formats, which are both OpenFOAM compatible i assume. Also, the flux profile can also be exported in a table format (100 x 100). Meaning
The 3D flux profile has energy density (W/m2) on the Z-axis, and the X, and Y-axis represent the cross section of the aperture (spot focus radius, r=3.0 cm).
The fundamental issue is coupling the exported 3D flux profile from Mathematica (in .STL or .VTK formats) with OpenFOAM software and using the flux profile as a radiation (heat source) boundary condition.
Also, I am using a Macpro with 64gb RAM and 12 cores. However 3d meshing using netgen on salome seems to take a very long time and always fails due to “ overlapping boundary”. So now am planning on using SnappyHexMesh, as it seems like the best method to apply.
kind regards
esujby is offline   Reply With Quote
Problem with Turbulent Heat Flux Temperature boundary condition Manuel CFD OpenFOAM Running, Solving & CFD 11 March 17, 2016 15:12
Temperature and heat flux wall boundary condition L. Hamid Main CFD Forum 3 February 22, 2014 21:10
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 07:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
