January 27, 2016, 13:21 |
Create a new Patch
Gabriele
Rep Power: 10 |
In the image below there is a part of cylinder on which i'm working. The circle in the foreground is my inlet pach ( i have imported the mesh from FLUENT), on this circle i have set an inlet boundary condition which implies an only water's input. I would create a new patch ( a concentric circle or a non-concentric circle, or an ellipse or if it is possible a surface of any shape) in order to have the possibility to set a double inlet boundery condition. On the original circle i want to have a water inlet boundary condition,while on the new patch (of the shape that I chose) i want to have a oil inlet boundary condition. For this purpose,i thought about using topoSetDict, but i haven't familiarity with this tool. I think my problem can be solved easily with openFoam. I hope I explained well my problem, and i hope there is someone who can help me. Thank you Leske |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
