How to set boundary condition for leakage water from a closed domain
Old   May 2, 2016, 03:40
Default How to set boundary condition for leakage water from a closed domain
hosseinfathi is on a distinguished road
Dear Foamers
I am trying to remove the water appears on the surface of grains in a domain. This domain is a pore scale model of a porous media. the water can be produced due to condensation or reaction. I want to remove this liquid water from the domain through one of boundaries (e.g. right).
What boundary conditions I should apply for interFoam at the outlet and also at the other boundaries?
I should mention that I used the following BCs and got illogical results:
Velocity: All patches except outlet and grains: zeroGradient
Outlet: pressureInletOutletVelocity
Grains: fixedValue=0
Pressure: All patches except outlet: zeroGradient
Outlet: fixedValue=0
alpha1: All patches except outlet: zeroGradient
Outlet: inletOutlet
Thanks for your helps in advance.
Regards,
Hossein
hosseinfathi is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 04:13
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 07:44
