September 19, 2011, 14:12 |
k-epsilon help
Ricardo
Rep Power: 14 |
I am kind of new to OF. I've been able to build a case for my purposes (flow around an object), but i want to explore more on the matter and need some help I am building my case using the Simple solver (im modeling for incompressible flow). i used one of the tutorial cases as my base, but i was wondering if anyone can point out to any resources that explain how to choose/compute the initial boundary conditions and values for the turbulence parameters ie epsilon, K, nut, nuTilda etc. How can i determine which bc to use and/or what value to assign. Any help is much appreciated. Thanks, Ricardo Last edited by rvmedina20; September 19, 2011 at 19:46. |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 16:34 |
simpleFoam ddt Euler ? | Mo-ITB | OpenFOAM Running, Solving & CFD | 2 | June 12, 2010 13:36 |
Naca0012 k-e mpirun gives fpe whereas simpleFoam not | Pierpaolo | OpenFOAM | 1 | May 8, 2010 03:08 |
Error running simpleFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 2 | August 29, 2008 09:42 |
