MapFields only on internal fields
Like Tree6Likes
  • 6 Post By aboth
Old   April 12, 2007, 05:37
Default Hi all, I would like to map
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Hi all,
I would like to map results from a mesh to another one with the same geometry but different boundary partitions (the number and the names of the patches do not correspond). However I'm not interested in mapping boundaryFields but only the internalFields.
I was not able to make mapFields work without the -consistent option.
Is there a way for mapping only values on the internalMesh?
Thanks a lot
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   June 23, 2015, 09:49
sgr
Simon Grützner
sgr is on a distinguished road
Hi Cosimo,
did you come up with an answer or a work around to your post? I have a case, where I refined certain regions using refineMesh. If I use mapFields to map field variables of the coarse Mesh on to the refined one, the internal Fields are not mapped. It is just the boundary conditions that are.
I dearly hope for a reply. Best regards,
Simon
sgr is offline   Reply With Quote
Old   December 1, 2015, 06:23
SM
canopus is on a distinguished road
The question in still unanswered!
internalField
and not boundary values?
canopus is offline   Reply With Quote
Old   December 1, 2015, 06:25
sgr
Simon Grützner
I have not found a way and stopped looking, but am still interested in a solution, of course.
Regards.
Old   June 14, 2017, 01:38
Ambrus Both
aboth is on a distinguished road
I think I found a way to do this. I know it is late for you, but for future reference I leave this here:
I use:
mapFields ../../014LuLaw188/baseCase/ -sourceTime 0.05 -mapMethod mapNearest -targetRegion region0
with a mapFieldsDict file with blank patchMap and cuttingPatches entries
E.g.:
cp ~/OpenFOAM/OpenFOAM-2.3.x/tutorials/lagrangian/DPMFoam/Goldschmidt/system/mapFieldsDict ./system/
The important part is the
Apparently region0 is the default name for the internal region if you do not specify names in blockMeshDict. (I do not have info on the default name used by other mesh generators.)
For me the mapping created some nan entries, and some programs cannot deal with this, so I substituted them with 0 by executing the following line in the 0 directory:
find ./ -type f -readable -writable -exec sed -i "s/nan/0/g" {} \;
aboth is offline   Reply With Quote
Old   May 5, 2020, 06:08
Default Field reinitialization in bynary with mapFields utility
Adriana Ferreira
Adriana Correia is on a distinguished road
Hello everyone,
The solution of Ambrus worked well for me.
In my case, I needed to do a field reinitialization by keeping the internal field and changing the boundary conditions. I had the same geometry with the same mesh refinement but as my files were in binary (to keep the double-precision) I couldn't change the boundaries manually, so the workaround I found was:
1. create the new files (p and U for example) with the desired boundary conditions
2. map the internal field from a previous case according to Ambrus instructions
I hope it may be useful if someone faces the same problem as me.
Best regards.
Adriana Correia is offline   Reply With Quote
MapFields Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Pre-Processing 18 September 28, 2017 11:06
MapFields does not work hartinger OpenFOAM Pre-Processing 13 September 22, 2014 03:14
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
MapFields turbulent pipe flow anita OpenFOAM Pre-Processing 5 July 3, 2008 23:29
MapFields cpplabs OpenFOAM Running, Solving & CFD 3 February 17, 2008 05:08
