Boundary condition and source in electromagnetic problems |
November 22, 2005, 09:06 |
Hi, everyone!
I'm a new user
Efimenko Evgenii
Rep Power: 17 |
Hi, everyone!
I'm a new user of OpenFoam, so I have a few questions. I'm trying to use OpenFoam to solve some electromagnetic problems. First of all, I don't understand do I need to write file "boundary" in "/constant/PolyMesh" or OpenFoam will generate it. If it will, how can it specify correct boundary conditions(I mean "physical type")? If I need to write this file on my own, how can I calculate "nFaces" and "startFace" for each patch? Second question. I need to specify zero tangential component of electric field at the boundary.(Normal component is arbitrary). Should I determine special physicalType for boundary condition? I hope you'd give me advise how to do it better. And the last question. I need to to specify source in the centre of my mesh as dipole alternately changing in time(= electric current). How can I do it? |
November 22, 2005, 10:26 |
I haven't used electromagnetic
VVqf
Rep Power: 17 |
I haven't used electromagnetic solver.
usually you don't need to write boudary file, OpenFoam will generate it when you do application to generate the mesh. But you can also write your own boundary file sometimes. please read User/Programming Guide, search for "boundary conditions", I think you can find what you want. |
March 5, 2007, 07:15 |
I am using mhdFOAM.
It s
I am using mhdFOAM. It seems that the boundary conditions we can impose on the magnetic field B are only of Dirichlet type (B constant). Is it possible to impose a Neuman type condition (given rotational of B, or imposed current)? thank u, Rita |
March 6, 2007, 15:20 |
Hi Rita
(With the choice of
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Rita
(With the choice of possible BCs you are refering to FoamX?) You can replace the fixedValue-BCs with fixedGradient (or mixed) in the B file. For the more complicated stuff (rotational etc) you might have to write your own BC
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
[Commercial meshers] Boundary condition problems (OpenFOAM) | Milos | OpenFOAM Meshing & Mesh Conversion | 13 | October 13, 2016 19:58 |
Boundary condition problems imported msh | milos | OpenFOAM Running, Solving & CFD | 8 | October 6, 2009 08:50 |
Problems implementing a boundary condition | ogloth | OpenFOAM Running, Solving & CFD | 3 | July 17, 2007 15:36 |
Problems with Fan boundary condition | Nish | FLUENT | 2 | August 27, 2004 18:27 |
Source balance and Boundary condition | Angela | Main CFD Forum | 0 | December 13, 2002 06:57 |
