Netgen multiple volumes
Old   February 11, 2005, 11:13
Default HI, I think Netgen is a ve
Pei-Ying Hsieh (Hsieh)
HI,
I think Netgen is a very nice tool for generating Tet elements. However, it only generate 1 volume at a time. If I generate two separate volumes (these two volumes will have common faces), is it possible to combine these two volumes into one volume and then set the common faces as internal bounday conditions?
Another issue with this apporach is that, how to ensure that the points generated on the common faces are the same on both sides so that they can be merged?
Pei
Old   February 11, 2005, 11:25
Default Hello Pei, if netgen does n
Mattijs Janssens (Mattijs)
Hello Pei,
if netgen does not do what you want you could try generating a single mesh and use the splitMesh utility to introduce the cut. splitMesh splits a mesh along internal faces (i.e. creates external faces from internal ones)
1] You will have to generate a 'faceSet' with all of the faces in it. A faceSet can be generated using the faceSet utility.
2] in the polyMesh/boundary file add two zero sized patches at the end.
Now
splitMesh
will try to split your mesh along the faces in the faceSet.
This is all a bit experimental so you might want to try it on a small hex mesh first.
Mattijs
Old   February 11, 2005, 14:44
Default Thanks Mattijs! The purpos
Thanks Mattijs!
The purpose of this really is related to gamma initialization. I am hoping to use the cell information (meaning cell numbers) inside specific blocks (volumes) and then initialize all these cells to gamma = 1. Ocassonally, I have to initialize gamma to 1 on irregular geometries.
Pei
Old   February 11, 2005, 15:00
Default You probably have studied the
You probably have studied the setGammaDamBreak utility which sets the gamma based on simple geometric info.
If you want it to use the netgen region info you will have to modify the netgenNeutralToFoam converter to read the region information as well and create a labelList with the region for every cell. Write this to a file and modify your setGammaDambreak to read this file and apply it.
[Netgen] Netgen now on Sourceforge philippose OpenFOAM Meshing & Mesh Conversion 71 November 13, 2014 07:44
[Netgen] Netgen v45 Release Candidate 2 philippose OpenFOAM Meshing & Mesh Conversion 2 April 29, 2008 16:58
[Netgen] Netgen and surfacecheck markc OpenFOAM Meshing & Mesh Conversion 1 March 27, 2008 15:43
[Netgen] Netgen under fedora 5 joegi OpenFOAM Meshing & Mesh Conversion 1 June 15, 2006 17:04
Netgen useful for CFDproblems nico OpenFOAM Pre-Processing 0 December 14, 2005 03:54
