Using patch-result as BC
Old   February 5, 2010, 04:27
Question Using patch-result as BC
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Hello, I am referencing this thread, but maybe posted in the wrong category: http://www.cfd-online.com/Forums/ope...condition.html
Is there a possibility to use the pressure distribution from a face (written as patch result), which will define the BC of the same face for another calculation.
I have set a body as patch, and in my result I am able to see the pressure distribution on this patch.
Now I want to use this pressure distribution as BC for using solidDisplacement solver.
But I didn't see any utility for that...
Any tip?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 5, 2016, 09:54
Amelie Rohlfs
AmRo is on a distinguished road
Hello Maxime,
I know, this thread is fairly old but it seems you're still active on this Forum.
Did you find an answer to your question? It sees I am in the same situation right now.
Greetings, Amelie
AmRo is offline   Reply With Quote
Old   July 6, 2016, 02:00
-mAx-'s Avatar
Maxime Perelli
Hello Amelie,
No I didn't get any clue, but in the mean time, the thread is 6 years old, and it is possible that actual OF version could do the job.
But unfortunately we switched on another software, and I am not aware what OF can now exactly do.
Old   July 6, 2016, 03:42
Justin Wiegmann
SirIsaac90 is on a distinguished road
Any tip?
Hi!
Maybe I have not understood your question correctly, but why you do not just copy it from your last time folder?
Okay, this is not a "glamorous" way, but with the same mesh it is of course possible.
Correct me, if I have misunderstood your problem.
Regards,
JW
SirIsaac90 is offline   Reply With Quote
Old   July 6, 2016, 03:56
-mAx-'s Avatar
Maxime Perelli
From one side I get the pressure distribution on a wall as result.
Then I wanted to get those results as BC for structure analysis.
Old   July 6, 2016, 05:13
Amelie Rohlfs
Exactly, that's my intention.
I want to use the pressure distribution as external load on my solid to simulate displacement.
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
