April 7, 2010, 07:43 |
wall functions for RAS models
Hi everyone,
is there a way to turn off the wall functions for the turbulent quantities in OpenFOAM 1.6? I'm a bit confused about this. I know that the RAS-models should be used with wall functions. But i want to compare the result with and without them to see the difference. Together with refining of my mesh. Thank you in advance, Eric |
April 8, 2010, 03:48 |
Michael
maybe you can use "calculated" instead of (for example) "nutWallFunction" in the nut-file of your 0-directory! But I'm not sure... |
April 8, 2010, 04:00 |
Michael
I tested it in the pitzDaily-tutorial and it worked (but I didn't checked the results)! I think you also have to change the boundary conditions for k and epsilon in 0-directory! I used zeroGradient instead of kqRWallFunction and epsilonWallFunction! |
April 8, 2010, 11:14 |
you can use several provided RANS turbulence models without (log-law) wall functions. At least on can use the k-omega and k-omega-SST models. There is also a modified k-epsilon model for that purpose, the launder sharma KE. If you are using the k-omega-SST model, I can tell you my setup for low-Re wall-treatment. For boundary conditions at the wall, k=0, mut=0, omega=omegaWallFunction. Note, that there is a new omegaWallFunction (very nice!) for low-Re wall-treatment. Therefore have a look at this thread. http://www.cfd-online.com/Forums/ope...megasst-2.html |
Wall functions for near wall treatment : k - epsilon model | fivos | Main CFD Forum | 4 | April 27, 2011 07:44 |
abt near wall turbulence wall functions | amv | Main CFD Forum | 0 | May 12, 2003 03:38 |
When I use the wall functions....! | maximus | Main CFD Forum | 7 | January 20, 2003 09:35 |
the problem of the wall functions | www_sun | Phoenics | 2 | March 13, 2002 19:15 |
Wall functions or low-Re models? | J. P. | Main CFD Forum | 7 | July 9, 1998 11:11 |
