cylindricalInletVelocity OpenFOAM
Like Tree4Likes
Old   November 23, 2010, 08:28
Default cylindricalInletVelocity OpenFOAM
alessio.nz's Avatar
Alex
alessio.nz is on a distinguished road
Is there a paper/document which explains the meaning of the cylindricalInletVelocity Boundary Condition for OpenFOAM? I need to set up an inlet velocity in a tube with the following features: 133 m/s axial velocity, 0 m/s radial, 77 m/s tangential (clockwise). I tried to use the following BC available but there are some lines I don't get, like: axis (0 0 1) , centre (0 0 0).
Can someone help me?
The BC is the following:
type cylindricalInletVelocity;
axialVelocity 133;
tangentialVelocity 77;
centre (0 0 0); //by default (0 0 0)
axis (0 0 1);
rpm 0;
radialVelocity 0;
value uniform (0 77 133);
alessio.nz is offline   Reply With Quote
Old   March 2, 2011, 20:23
N. A.
N. A. is on a distinguished road
Hey Alessio,
Were you able to get the information about axis and center?
I dont know if the axis is in cartesion cordinate system or cylindrical.
Thanks,
Nir
N. A. is offline   Reply With Quote
Old   March 3, 2011, 01:55
Alan Russell
AlanR is on a distinguished road
Alessio,
The best way to understand OF is to look at the source code. For your BC, look in src/finiteVolume/fields/fvPatchFields/derived/cylindricalInletVelocity. Looking through the .C and .H files usually tells you a lot. I think the Center (0 0 0) is the center of your cylindrical inlet, which is set to (0 0 0) by default. If your mesh geometry is different, use the input vector to align it. The axis vector is to specify the direction of axial flow (0 0 1) being positive z.
I usually search the forum to see if there are relevant posts, then I will look through the source code. Good luck,
Alan
babakflame, Howard and vivek05 like this.
AlanR is offline   Reply With Quote
Old   March 3, 2011, 07:52
alessio.nz's Avatar
Alex
Hi Nir, the system I was talking about was cylindrical. Axis and center refers to the mesh ones. The axis is the z, also considered as axial.
Old   March 3, 2011, 07:57
alessio.nz's Avatar
Alex
Hi Alan, the problem was not so trivial: if you consider the situation, what I needed was a flow with axial and tangential velocity. The axial velocity of 133 m/s and tangential one of 77 m/s. The tangential obtained in the BC of Cyl BC was not the right one, because it is depented on the radius of the inlet tube, meaning that if I have a rpm value and a diameter, this tangential velocity is radius dependent, while, what I actually need, is a uniform tangential velocity (which has to recreate the swirler conditions). What I would like to set up a tangential velocity as I could do for the radial one (see the lines). Do you think is it possible?
Old   April 26, 2011, 11:41
Default cylindricalInletVelocity needs revision
Alex Wouden
amwouden is on a distinguished road
Send a message via Skype™ to amwouden
Alex, the case you described is exactly what I've wanted from the cylindricalInletVelocity condition. The best way I found was to just modify the source code. The modified library is attached.
Firstly, there are a few things that I have learned.
1) the center point is in Cartesian coordinates; very few, if any, OpenFoam utilities are in Cylindrical coordinates
2) at no point in the library is a component defined in Cylindrical coordinates. Rather, radial and tangential are defined in the form (x-contribution, y-contribution, 0)
3) the specification for the radial and tangential velocities are incorrectly scaled. Note below that the variable "d" is the relative radial-tangential distance between the cell-face center and the "centre". The "d" used in subsequent calculations should be replaced with a "dhat" where
vectorfield dhat = d/mag(d)
This adjustment should clear the radial-dependent scaling on the components.
As contained in cylindricalInletVelocityFvPatchVectorField.C (I've added a few comments):
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
void Foam::cylindricalInletVelocityFvPatchVectorField:: updateCoeffs()
if (updated())
return;
vector hatAxis = axis_/mag(axis_); //unit-vector of axial coordinate
vectorField r = (patch().Cf() - centre_); //relative distance vector
vectorField d = r - (hatAxis & r)*hatAxis; //subtract out axial component
vectorField tangVelo =
(rpm_*mathematicalConstant:: pi/30.0)*(hatAxis)^d;
//recall: hatAxis^hatRadial=hatTangential, therefore tangVelo = omega*hatTangential
operator==(tangVelo + axis_*axialVelocity_ + radialVelocity_*d);
//splice xyz components from tangential-axial-radial
fixedValueFvPatchField<vector>::updateCoeffs();
The modified library allows for a more convenient specification, namely
inlet
axis (0 0 1);
centre (0 0 0);
radialVelocity -10;
tangentVelocity 10;
axialVelocity 30;
value (0 0 0);
//the value is not really necessary for the condition but OpenFOAM give me an error if I don't include it.
I've attached the new library folder. Simply unzip the folder into a convenient place and run
wmake libso
amwouden is offline   Reply With Quote
Old   May 2, 2011, 12:01
alessio.nz's Avatar
Alex
Thanks Alex, it is very usefull!
considering I am not very familiar with the libraries, if I compile this version you attached, which has got the same name of the default one in OF, do you suggest me to change the name, or simply shall I compile and then the previous default one will be replaced?
i will try to run simulation and check if it works, with the inlet values you gave me.
thanks for the help!
cheers,
alessio
Old   March 28, 2012, 14:33
Default OpenFoam 2.1 version version
Alex Wouden
In OpenFOAM 2.1, the compiling structure has changed to some degree. Attached is the drop-and-run source code for the cylindricalInletVelocity. Because OF2.1 has a native condition of the same name (which I have reservations against using for the reasons in a previous post), the name of the condition has been altered to cylindricalVelocityInlet.
1) uncompress the file to a convenient location. I use my openfoam user folder.
2) compile using: wmake libso
3) the boundary condition should compile smoothly. The condition can be applied to the velocity on a patch. in the initial condition specify
type cylindricalVelocityInlet;
axis (x y z); // axis of rotation
centre (x y z); // axial center
radialVelocity scalar; // V_r
tangentVelocity scalar; // V_theta
axialVelocity scalar; // V_z
value uniform (0 0 0); // not necessary, but paraView results in an
error without it
S_teph_2000 likes this.
Old   March 25, 2013, 12:56
Default Use of classical cylindricalInletVelocity in OF 2.0.x
Gregory Paladin
paladin is on a distinguished road
Hi Foamers !
I am trying to simulate a swirling flow with an anular inlet, and therefore I'd like to use the cylindricalInlet Velocity. (OF 2.0.x)
I'll have to run my simulation on a cluster so I can't use any additional user library suggested above...
Does anyone knows if this boundary condition works properly?
Even when I change de rpm, the velocities, etc, i still get this error :
Starting time loop
Courant Number mean: 4.24721e-05 max: 0.0535831
deltaT = 2.85714e-06
Time = 2.85714e-06
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM FATAL ERROR:
attempted copy of a deallocated temporary
    From function Foam::tmp<T>::tmp(const tmp<T>&)
    in file /Volumes/OF/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude/tmpI.H at line 63.
FOAM aborting
The same simulation with a simple "fixed value" condition and an axial component works just fine.
Anyone has an idea? I am no OF expert, so I don't even understand what the error means...
Thanks in advance !
paladin is offline   Reply With Quote
Old   March 25, 2013, 13:16
Alex Wouden
What does your initial condition file for U look like?
The cylindricalInletVelocity of OF2.x should work.
Old   March 25, 2013, 13:55
Gregory Paladin
Here is the burner geometry : http://cl.ly/NpGk
My swirling jet is between the bluff body (r=25mm) and the annular shroud (r=30mm)
The axial velocity is 16.3m/s and the tangential velocity 25.9m/s. Axis is in the X direction.
Here is my boundary condition in 0/U
	Pilot
	axis (1 0 0);
	centre (0 0 0);
	axialVelocity 16.3;
	rpm 8244;
	radialVelocity 0;
RPM 8244 seems high but 25.9m/s tangential velocity for a 30mm annulus... I double checked the maths.
I had to put a "value" keyword, otherwise it doesn't run.
Thanks for your help
Old   March 25, 2013, 15:01
Alex Wouden
After looking into it a bit further, I am noticing the same error with the native bc that is available.
The error is associated with the handling of the tangential component. In the source code:
tmp<vectorField> tangVel
(rpm*constant::mathematical:i/30.0)*(hatAxis) ^ d
By some unknown reason, it is trying use this variable without allocating it properly.
Unless you can modify the source code or use one of the user libraries above. I don't know what to suggest.
Old   April 24, 2013, 17:25
Vishal Achasrya
vishalsacharya is on a distinguished road
Why cant you use the user libraries on a cluster?
I know the installation is in a non-default place and the env vars are set based on those. But the *_USER dirs can be set to you where you want your src and lib folders to be and then when you "wmake libso" user codes, it would put them there. Then you can just add the appropriate .so files to your controldict and it should work.
vishalsacharya is offline   Reply With Quote
Old   May 9, 2014, 04:02
marcaurel is on a distinguished road
Hi Alex!
I'm using OpenFOAM 1.6-ext and I would also like to use your cylindricalInletVelocity BC. Have you already adjusted your version to OF 1.6-ext because there is a big difference to OF 2.x and my programming knowledge is a bit limited ?
BR
Markus
marcaurel is offline   Reply With Quote
Old   May 14, 2014, 04:16
sirLentschi
lentschi is on a distinguished road
Hello Markus,
you can find the appropriate file for OF-1.6-ext at
http://www.cfd-online.com/Forums/ope...tml#post305143
lentschi is offline   Reply With Quote
Old   August 28, 2014, 01:28
Default help
  #16
Ndong-Mefane Stephane Boris
S_teph_2000 is on a distinguished road
error without it
How would you proceed if your inlet velocity components were all functions of the radial direction:
radialVelocity scalar; // V_r =f1(r)
tangentVelocity scalar; // V_theta =f2(r)
axialVelocity scalar; // V_z=f3(r)
Stephane
S_teph_2000 is offline   Reply With Quote
Old   February 10, 2015, 04:21
  #17
Chrisi1984 is on a distinguished road
Hello Stephane,
were you able to adapt the BC with the radius dependant values? I would also need such a BC.
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   May 7, 2015, 11:58
Howar
Howard is on a distinguished road
Originally Posted by AlanR View Post
Alessio,
Alan
Hello, Friends! I think what you said is quite meaningful. Could I ask how learn these information or skills, learning C++? And like this situation, how do you know to look up the SRC/...derived document? Thank you!
Howard is offline   Reply With Quote
Old   June 28, 2017, 05:57
Default strange tangential velocity
  #19
sitajeje is on a distinguished road
Dear Foamers,
I set the cylindricalInletVelocity as the following:
lateral
axis (0 0 1);
centre (0 0 0);
axialVelocity constant 0;
radialVelocity constant 0.3;
rpm constant 955;
The radius of the cylindrical boundary is 3mm. Therefore the tangential velocity is the same as the radial velocity, and the velocity vector at this boundary should be 0.42m/s, with 45° deviating from the tangential/normal direction of the boundary. However the resulting inlet velocity was 0.37m/s and closer to the normal direction of the boundary, as you can see in the attached image. Did I misunderstand something? I would appreciate if anybody can give me some suggestions!
Best regards,
sitajeje
sitajeje is offline   Reply With Quote
Old   July 3, 2018, 09:48
Default Accuracy of the results regarding inlet volumetric flow
  #20
Matthias Frechen
Matthias Frechen is on a distinguished road
Hi All!
We usally use cylindricalInletVelocity for square swirl diffusers, but we are not totally convinced by the accuracy of the results regarding inlet volumetric flow when using a single square inlet area. The resultant inlet volumetric flow we see in Paraview seems to be about 20- 30% to low compared to the axialVelocity we put in the input file.
Does anyone tried to use swirlFlowRateInletVelocityFvPatchVectorField or groovyBC for swirl diffusers or a different approach with promising results?
Regards
Matthias
Matthias Frechen is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
