patch with different bc
Old   May 25, 2011, 05:04
Default patch with different bc
conny
madeye is on a distinguished road
Dear All,
first of all i hope this is posted in the right spot, i am new to all of this, so please fogive me 'stupid' questions.
My question is, if there is a way to put two different boundary conditons in one patch.
I'm using interFoam (1.5) to simulate a multi-phase channel flow, but the outflow in the end of the channel is not completely open, but has a triangular shape. I can't quite explain, so I made a drawing.
The issue is that I have to set gamma, pd and U in different BCs, whereas for the outlet:
U: pressureInletOutletVelocity
pd: totalPressure
gamma: inletOutlet
and for wall:
U: fixedValue
pd: zeroGradient
gamma: zeroGradient
Is there any way to do it like nonuniform BC like here http://www.cfd-online.com/Forums/ope...condition.html since i can't make patches out of 3 vertices?
I'm happy for any help!
Thanks a lot in advance
Conny
madeye is offline   Reply With Quote
Old   July 4, 2011, 08:08
Bernhard Linseisen
Linse is on a distinguished road
Hi Conny,
to my knowledge (which can be wrong!!) it is not possible to set something like a split boundary condition.
But what you could do: Make four blocks with a triangular shape instead of two rectangular blocks. Usually you should be able to define that by putting two side-lines of the building block onto each other.
For example if usually you have
block (0 1 2 3 4 5 6 7) for the rectangular one, you could use
block (0 1 6 7 4 5 6 7) for the first block and
block (0 1 2 3 0 1 6 7) for the second block.
I do not know if that is a nice solution. But some time ago it worked at least for building the basis structure of something...
Linse is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
