Initial conditions for simulation
Old   June 1, 2011, 09:47
Question Initial conditions for simulation
lazersos@gmail.com
lazersos is on a distinguished road
I'm working on a steady-state flow problem where there is a non-uniform (but constant) vector field (magnetic field). I'd like to implement this in the code but I'm running into issue finding the relevant examples. First, is the vector field defined at the center of the cells or at the edges. Second, I can already calculate the three cartesian components of the field given the cartesian coordinates of the point at which I want to know the field. How exactly should I go about implementing this?
I was thinking some code like:
label internalPatchID = mesh.??????
fvPatchVectorField& B=B.internalField()[internalPatchID];
const fvPatchVectorField& centre = mesh.C().internalField()[internalPatchID];
scalarField x = centre.component(vector::X);
scalarField y = centre.component(vector::Y);
scalarField z = centre.component(vector::Z);
Here's a third problem. How do I loop over the individual elements of x y and z. If I had a function which provided the field like:
B==func_bx(x,y,z)*vector(1,0,0)+func_by(x,y,z)*vector(0,1,0)+func_bz(x,y,z)*vector(0,0,1);
would that work?
Anyone have a good reference to this information?
lazersos is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
