New transformation option for utility: transformPoints |
January 13, 2012, 17:02 |
Philippose Rajan
Rep Power: 25 |
Hello and a Good Evening,
Today I had the need to rotate my mesh along a specific axis, which does not pass through the origin..... an arbitrary axis defined by two points. As far as I can see, none of the rotation transforms in the mesh utility: "transformPoints" allows this kind of a rotation about an arbitrary line..... or am I wrong? In order to achieve my requirement, I added on one more command line option to transformPoints: "-rotateAlongLine", which allows the mesh to be rotated along any arbitrary axis which does not need to pass through the origin, and is defined by: 1. A point which lies on the axis P1(x,y,z) 2. A direction vector which defines the axis, which would typically by P2 - P1 (where P2 is another point on the line which defines the axis) 3. The required rotation angle (in degrees) Hence, the new command-line option looks like this: Code:
transformPoints -rotateAboutLine "(0 -0.05 0) (1 1 0) 45" ----------- The implementation of this option is as follows: 1. Translate the mesh such that the given point becomes the origin of the mesh....: Code:
points -= pointOnLine; Code:
tensor T = RodriguesRotation(dirVector, rotationAngle); points = transform(T, points); Code:
points += pointOnLine; It would be great if someone could add this to the Git repository of the OpenFOAM-1.6-ext project....? Unless this kind of operation is already possible (without having do it manually by using three calls to transformPoints i.e. :-)!) If required, I can put up a zipped copy of the modified "transformPoints" utility. Philippose |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
