Inlet profile from 2D velocity and turbulence data |
March 10, 2012, 04:26 |
Attesz
Rep Power: 17 |
Hi Foamers,
I'm dealing with a simple 3D pipe. I have measurements at the inlet, which is the radial and axial velocity, turbulentKE and nut in terms of the radial distance from the wall. I want to impose this data in U, k and nut and calculate epsilon. 1. If I define my parameters as in the pitzDailyExptInlet tutorial, that is giving the coordinate of the points and the give the values, I'll have the values along one line at the inlet, right? So the values will be interpolated to the nodes? 2. How can I "rotate" the values all along the inlet face to have the data everywhere? Is there a specific BC for that? I'm thinking about cylindricalInletVelocity BC type, but what about k and nut? Thank you in advance, Attila |
2d data, inlet bc, interpolation |
Export & Import Velocity profile as Inlet | eRzBeNgEl | STAR-CCM+ | 6 | March 26, 2012 05:16 |
Velocity profile regarding turbulence ??? | Aminullah | Fluent UDF and Scheme Programming | 0 | November 18, 2010 01:36 |
Specify Inlet Velocity Profile | JHardes | ANSYS | 1 | March 17, 2010 13:59 |
inlet velocity profile for fully developed turbule | pankaj saha | Main CFD Forum | 4 | August 24, 2007 16:53 |
