How can I output slices of the flowField via sampledPlanes
Old   May 25, 2012, 03:29
Default How can I output slices of the flowField via sampledPlanes
Martin
wernsen is on a distinguished road
Hey guys,
here is my problem. I am using sampledPlanes to gather informtions of the calculated field. I can also write the mesh of these planes via "sampledPlanes().write(file_name)" after an update.
The question is now, how can I export for example the velocity distribution on this plane. I can use the vealues via "sP.sample(U.component(1))" for example to get the y-component. But I want to have the slice like it is in paraview.
I had a look to the sample utility but unfortunately I can not help myself.
Would be nice to get help.
MARTIN
wernsen is offline   Reply With Quote
Old   May 29, 2012, 04:07
Jim Knopf
JimKnopf is on a distinguished road
Hi
as far as i know there is a function object to sample plane lines and probes during calculation. I'm not sure about the syntax, but maybe you can have a look at it.
The function object needs to be defined in the control dict.
HTH
Jim
JimKnopf is offline   Reply With Quote
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 01:59
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Output transient file to csv Ben CFX 3 September 23, 2008 08:17
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 04:28
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 16:58
