June 15, 2012, 09:51 |
Interpolation from particles (points) to vol
Rep Power: 16 |
Dear Foamers,
I am looking for a possibility to interpolate values from lagrangian particles to the mesh volumes. Each parctile holds a separate value, such as a weight or whatever. What I need is an area-weighted field of all particles (many of them!). One possibilty would be to loop over all cells (or particles) and just average the values of all particles within one cell. However, the area-weighting is lost by doing this. As far as I see it, the class pointVolInterpolation "only" interpolates from a full pointMesh to a volMesh and cannot be used for my problem. Am I right? Any ideas? Thanks in advance! |
June 15, 2012, 14:25 |
Mahdi Hosseinali
Rep Power: 18 |
I'm new with foam programming too, so maybe my words does not make sense for in this aspect
I think you should define an fvMesh which is moving and can be updated using .update() method, this would be your lagrangian mesh, and a stationary mesh which is your eulerian mesh. to have a area weighted average you shoudl use .Sf() and to use volume weighted .V(), a mass weighted would then be easy by multiplying .V() and rho |
June 18, 2012, 04:50 |
Rep Power: 16 |
Hi all,
what I am looking for is a pointVolInterpolation which interpolates values from lagrangian particles to the cell centeres (not from mesh points to cell centeres as the existing pointVolInterpolation). So, the input needs to be a list of coordinates and scalars, output should be a volField<scalar>. As an alternative, a pointPointInterpolation would also help, meaning an interpolation from particles to mesh points. Any ideas or hints for classes that could be adopted? Or can the existing pointVolInterpolation be used for that? |
Interpolation between faces and points of a polyPatch | hartinger | OpenFOAM Running, Solving & CFD | 12 | March 7, 2016 13:08 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
