Real Gas EOS
Like Tree7Likes
Old   June 29, 2012, 08:46
Default Real Gas EOS
Francesco Capuano
francesco_capuano is on a distinguished road
Hi everybody,
I would like to implement a real-gas equation of state (e.g. Peng-Robinson).
In a very old thread,
http://www.cfd-online.com/Forums/ope...eal-gases.html
some general tips were given; however, any further suggestions (particularly for OpenFOAM 2.0.x or 2.1.x) would be greatly appreciated. Besides, I was wondering if there are any already implemented versions of real-gas EOS which are available on the web.
Thanks in advance.
Francesco
immortality likes this.
francesco_capuano is offline   Reply With Quote
Old   July 2, 2012, 03:17
Christian Lucas
Chris Lucas is on a distinguished road
you can find a real gas implementation (redlich Kwong, Peng Robinson ...) for OpenFOAM in OpenFOAM ext. .
http://openfoam-extend.git.sourcefor...-ext;a=summary
Have a look at the branch feature/fullyIntegratedRealGasThermo.
Best Regards,
Christian
labyrinth01 likes this.
Chris Lucas is offline   Reply With Quote
Old   July 2, 2012, 06:00
Francesco Capuano
Dear Christian,
thank you very much, that is exactly what I am looking for. I cannot compile it, though. Is it possible to make the library compatible with OpenFOAM v. 2.x? I see that many files are missing in the newer versions (for instance all those in the reaction/reactions folder).
Thanks again,
Francesco
Old   July 2, 2012, 07:01
Christian Lucas
I have no version of the code for OpenFOAM 2.0 but you can rewrite the code yourself. Have you tried the code in OpenFOAM 1.6 ext.?
Best Regards,
Christian
Old   July 2, 2012, 08:47
Francesco Capuano
Thanks for your reply. I haven't tried it yet, but I will soon and let you know.
Best regards,
Francesco
Old   July 5, 2012, 08:30
Gitesh
Gitesh P is on a distinguished road
Hello Christian,
Can you give some more detail for how to use these codes ?
Regards,
GP
Gitesh P is offline   Reply With Quote
Old   July 6, 2012, 03:19
Christian Lucas
have a look at the pipe tutorial for rhoPisoFoam. All possible thermodynamic models are shown in the thermodynamicProperties dict. Additionally, have a look at the fvSolution of this case. The flag realFluid should be set to true (This changes the pressure equation a bit). For more infomation have a look at the solver code (rhoPisoFoam, pEqn). If you want to use a different solver, the pressure eqn. in this solver must be changed as well (as I did in rhoPisoFoam)
If you have further questions, please ask
By the way, I finished programming the steam tables and are testing them at the moment. Hope to upload them soon.
Christian
Old   July 13, 2012, 08:37
Francesco Capuano
Hi Chris,
I have installed OpenFOAM 1.6-ext but still have some problems with the real-gas libraries. I am particularly interested in simulations involving reacting mixtures: are your libraries able to deal with those cases? Which packages do I have to install from the repository? It seems to me that "real gas EOS for mixtures" and "mixture version of real gas EOS" are not sufficient, aren't they?
Thank you very much, regards,
Francesco
Old   July 13, 2012, 08:43
Christian Lucas
"Which packages do I have to install from the repository?"
--> the latest one
"It seems to me that "real gas EOS for mixtures" and "mixture version of real gas EOS" are not sufficient, aren't they?"
your correct, at the moment the real gas classes are not connected to the reaction library. You have to connect them yourself. I'm not sure how difficult this is.
Regards,
Christian
Old   July 17, 2013, 05:36
Default records
Sergey
Servalun is on a distinguished road
Dear Christian,
I downloaded your real gas implementation code for OpenFoam. I have successfully modified it and now I'm using it for my needs. First of all thanks - great job. I want now to summarize my efforts. Do you have some documentation or records of what you did, that you can share?
Best regards,
Sergey
Servalun is offline   Reply With Quote
Old   July 23, 2013, 05:15
Default Real gas implementation code for OpenFoam
  #11
Gitesh
Hello Sergey,
Nice to know that!
Could you tell me in which version of OpenFOAM you are using for Christian's real gas implementation?
With regards,
GP
Old   July 25, 2013, 03:21
Christian Lucas
he is using OpenFOAM 2.1. I also have a real gas version for OF 2.1 and might release it soon (problem at the moment is to find the best way to do it). Sergey, you can add your stuff afterwards ( if you like )
Regards,
Christian
PeterBishop likes this.
Old   August 14, 2013, 11:32
Christian Lucas
HI,
I finally finished the work. You can download the real gas library for OF 2.1 here:
git clone https://github.com/morgoth541/of_realFluid.git
Christian
Old   August 26, 2013, 11:18
Peter Bishop
PeterBishop is on a distinguished road
I downloaded your library from git repository and tried to compile on my exisiting installation of OF2.1, but when I try to compile thermophysicalModels/basic I get the following error
psiThermo/realGasEThermo/realGasEThermos.C(61): error: argument list for class template "Foam::realGasEThermo" is missing
I'm using Intel compiler 13.0.1.
Moreover the following include appears in basicMixtures.C
#include "binaryMixture.H"
it seems this file does not exist anywhere.
Thanks in advance for your reply and for sharing your work.
PeterBishop is offline   Reply With Quote
Old   August 26, 2013, 13:25
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
how can download it in GitHub?
is it applicable for 2.2.0 version?
and which model is suitable for air in pressures in the range of:200000pa-1.8Mpa
and temperatures of :300-1300K?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 27, 2013, 03:08
Christian Lucas
Hi Peter,
thank you for your response. I found the error (forgot to add one file) and I will push the update after work.
@immortality
it a git repository, use the command in the consol
Christian
Old   August 27, 2013, 05:46
Ehsan
Hi dear Christian which model you have used in the code?Van Der Waals or what?
is it appropriate to my case in ranges of p and T I told before?
Old   August 29, 2013, 02:59
Christian Lucas
Hi
have a look at the repository README file. The new models are explained there.
Christian
Old   September 20, 2013, 05:19
Peter Bishop
Hi Chris,
I downloaded your real gas implementation from your repository and successfully compiled it on my existing of 2.1 installation. Everything works like a charm
At the moment I'm trying to make some validation of realFluidPISOSolver, simulating transcritical injection of nitrogen jets, for which there are in literature some experimetal data. In this regard should be very useful to let the solver write the specific heat field, have you any suggestion?
Old   September 20, 2013, 08:18
Christian Lucas
have a look at createFields:
copy and rename "volScalarField rho". Change thermo.rho() to thermo.Cp(). Then, update the new field each time step.
Christian
high pressure injection, openfoam 2.1.x, real gas
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
error message cuteapathy CFX 14 March 20, 2012 06:45
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
