creating geometricField unknown Type in main(){}
Old   July 6, 2012, 02:07
Default creating geometricField of unknown Type in main(){}
Artem Shaklein
ARTem is on a distinguished road
Hello, FOAM'er users!
I'd like to create post-proc time averaging utility, something like that (_http://www.cfd-online.com/Forums/openfoam-programming-development/70396-using-fieldaverage-library-average-postprocessing.html), but without using createField.H and etc. E.g. "average U" or "average p".
So, as base foamCalc utility was used. But, it seems to me, that I have to initialize averagedField of unknown type (<vector>, <scalar> etc.) right inside main function before starting cycle on stored time steps.
int main(int argc, char *argv[])
   // Reading information about field to be averaged
    IOobject fieldHeader
        fieldName,
    // Defining fieldType by some means
    fieldType averagedField
        IOobject
            "averaged" + fieldHeader.name(),
    // Averaging procedure
    forAll(timeDirs, timeI)
FoamCalc is to initialize geometricField, e.g. interpolateField, of unknown type. But, that can be done inside user function, called by cycle at each stored time step, using <template>. InterpolateField from old time steps isn't needed at new time step, so it can be initialized at each time step.
        // template<class Type> void writeInterpolateField is called, where interpolationField is initialized, calculated, stored and destructed
        writeInterpolateField<scalar>(fieldHeader, mesh, processed);
        writeInterpolateField<vector>(fieldHeader, mesh, processed);
        writeInterpolateField<sphericalTensor>(fieldHeader, mesh, processed);
Is it real to create geometricField of unknown type right inside main function? Or are there other ways to approach final goal?
Thank you very much for your attention.
ARTem is offline   Reply With Quote
Old   July 7, 2012, 18:11
Assistant Moderator
Bernhard Gschaider
        fieldName,
        IOobject
No you can't. All these fields are instantiations of GeometricField but have no common base-class except regIOobject (which you could use, but the resulting cast-orgies won't simplify the elegance of your code. If there was a better way the guys who wrote foamCalc would use it (they really know what they're doing)
Old   July 9, 2012, 02:10
Artem Shaklein
gschaider, thank you for detailed explanation.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 15:37
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
