Different implementation pEqn.H in pimpleFoam vs interPhaseChangeFoam
Like Tree1Likes
  • 1 Post By danny123
Old   November 28, 2015, 13:10
Default Different implementation pEqn.H in pimpleFoam vs interPhaseChangeFoam
Daniel Rodriguez Calvete
DanielRCalvete is on a distinguished road
I am confusing about the implementation of pEqn.H in pimpleFoam vs interPhaseChangeFoam:
From Non-orthogonal pressure corrector loop, pimpleFoam is written:
// Non-orthogonal pressure corrector loop
while (pimple.correctNonOrthogonal())
    // Pressure corrector
    fvScalarMatrix pEqn
        fvm::laplacian(rAUf, p) == fvc::div(phiHbyA)
    pEqn.setReference(pRefCell, pRefValue);
    pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter())));
    if (pimple.finalNonOrthogonalIter())
        phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
p.relax();
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
fvOptions.correct(U);
Since in interPhaseChangeFoam is:
        fvScalarMatrix p_rghEqn
            fvc::div(phiHbyA) - fvm::laplacian(rAUf, p_rgh)
          - (vDotvP - vDotcP)*(pSat - rho*gh) + fvm::Sp(vDotvP - vDotcP, p_rgh)
        p_rghEqn.setReference(pRefCell, pRefValue);
        p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter())));
            phi = phiHbyA + p_rghEqn.flux();
            U = HbyA + rAU*fvc::reconstruct((phig + p_rghEqn.flux())/rAUf);
    p == p_rgh + rho*gh;
    if (p_rgh.needReference())
        p += dimensionedScalar
            "p",
            p.dimensions(),
            pRefValue - getRefCellValue(p, pRefCell)
        p_rgh = p - rho*gh;
Two main differents and questions:
1) In pimpleFoam U is solved outside the while condition, since in interPhaseChangeFoam is inside it.
My firts thought was that the U is not solved in interPhaseChangeFoam if we set nonOrthogonalCorrector = 0, what is very strange. But seing the solutionControl Class (in particular solutionControlI.H) I find that is added 1 to nNonOrthCorr, therefore I guess that non-Othogonal correction is solved at least one. My questions are:
a) am I correct on this?
b) is any difference in the final solution between putting U reconstruction inside or outside the [CODE] "while" ?
2) In interPhaseChangeFoam the p.relax() does not exist, therefore if we use pimple Loops outerCorr > 1, it is not applied relaxion factors.
c) Does anybody knows why is not p.relax() in the code, or if I miss somewhere where is applied it?
Thank you to anyone who can help me.
Regards,
DanielRCalvete is offline   Reply With Quote
Old   December 4, 2015, 10:37
Daniel Witte
danny123 is on a distinguished road
Hello DanielRCalvete,
Logically thinking I would guess the following:
1. The Pimple solver was designed before the interPhaseChangeFoam solver
2. You cannot call pEqn.flux() without pEqn being solved
So, this explains why there is that if-clause to calculate phi at the end of each pEq solving loop. If you set the number of nonOrthogonal corrections to -1, the call pEqn.flux() will lead to an error. I do not know why you would do this, but some people apparantly did.
Later, interPhaseChangeFoam was made and the same issue has been found about U. Look at the different code for U.
Regards,
Daniel
Ramzy1990 likes this.
danny123 is offline   Reply With Quote
implementation of mapFields into parallel transient case simpomann OpenFOAM Pre-Processing 4 August 2, 2016 04:41
Implementation of Temperature Eqn in InterPhaseChangeFoam Jibran OpenFOAM Running, Solving & CFD 14 June 17, 2015 10:47
Implementation of pimpleFoam to incorporate pollutant dispersion None OpenFOAM Programming & Development 0 April 24, 2014 03:04
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 12:43
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 05:10
