Finding calculation of T_ field
Prev Previous Post   Next Post Next
Old   July 27, 2012, 09:02
Default Finding calculation of T_ field
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I want to implement the wallHeatFlux BC for the T-Field in my solver. For now I can use the BC but the calculation of the T faces of the boundary is not working. I get still the values of the initial Temperature (its like i have a fixedValue BC).
How do I test the values of the T_ faces?
After calculate of hEqn.H there is the thermo.correct() code.
I had a look at the correct function and there I found that:
template<class MixtureType>
void Foam::hPdfThermo<MixtureType>::correct()
        // force the saving of the old-time values
        psi_.oldTime();
        if (counter == propertyUpdate)
                Info << "Updating look-up table extractions..." << endl;
                update();
                counter = 0;
        if (counter_mass_fractions == massFractionsUpdate)
                Info << "Updating mass fraction extractions..." << endl;
                updateMassFractions();
                counter_mass_fractions = 0;
        Debug();        // added by myself
        calculate();
        counter++;
        counter_mass_fractions++;
And in the Debug-Function I am getting the face-values:
void Foam::hPdfThermo<MixtureType>::Debug()
        Info << "Debug" << endl;
        forAll(csi_.boundaryField(), patchi)
                if(isA<wallHeatTransferFvPatchScalarField>(T_.boundaryField()[patchi]))
                        const fvPatchScalarField & pcsi = csi_.boundaryField()[patchi];
                        const fvPatchScalarField & pT   = T_.boundaryField()[patchi];
                        forAll(pcsi, facei)
                                Info << "T = " << pT[facei] << endl;
Now my question is, how can I figure out why the BC wallHeatTransfer is not working, or is it working and I made some errors?
Normally I should get different values of the face-values (or not?) ...
And if I get the enthalpy equation. Where is the solver solving the temperature eqn or calculate it from the enthalpy?
Tobi
Tobi is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 22:28
how to impose fixed value at a point (or region) during calculation ? Cyp OpenFOAM Programming & Development 25 February 29, 2012 02:42
Phase field: calculation of the |grad f| div(grad f/|grad f|) term Alucard OpenFOAM 0 November 2, 2011 09:44
Need help evaluating field by interpolation with a "lookup table" JohnRHawk OpenFOAM Programming & Development 2 June 28, 2011 13:27
