Automate execution of command line
Old   April 5, 2012, 06:42
Default Automate execution of command line
Rider is on a distinguished road
I would like to automate execution of command line with a script (On Ubuntu). Moreover, I want that the second line begin when the first line is finished.
For exemple :
* cd User/Cas1
* blockMesh
* snappyHexMesh
* sudo cp Cas1/0 Cas1/3 // copy of the boundary conditions
* decomposePar
* foamJob -parallel -screen simpleFoam
* reconstructPar
* cd User/Cas2
* blockMesh
* snappyHexMesh
* decomposePar
* reconstructPar
* cd User/Cas2
* etc ...
Thanks all for your help
Rider is offline   Reply With Quote
Old   April 5, 2012, 07:01
akidess's Avatar
Anton Kidess
That's the default behaviour. Just put all the commands from above in a file that starts with the line "#!/bin/bash", and then run "chmod +x [scriptname]" to make the file executable. That's it.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 5, 2012, 07:54
Ok.
The file is a text file (.txt) ?
Old   April 5, 2012, 08:05
akidess's Avatar
Anton Kidess
The file is plain text, but the extension is not important. I usually end them in .sh, but if you prefer you can use .txt, or no extension at all.
Old   April 5, 2012, 08:36
Ok, thanks.
Edit : It works
Old   April 6, 2012, 05:52
Is it possible to use the script to modify the parameters of velocity inlet in the text file ?
Old   April 6, 2012, 07:34
akidess's Avatar
Anton Kidess
Yes. Learn how to use sed or awk to manipulate text files.
Old   April 9, 2012, 18:04
Assistant Moderator
Bernhard Gschaider
That is a possibilty. Although these straight replacements always have to make an assumption about what they have to replace ("look for value 42 and replace it with the inlet velocity"). I personally find a solution similar to http://openfoamwiki.net/index.php/Co...ions_for_walls much easier to maintain (but of course I'm not objective)
But of course sed has the advantage to be installed everywhere
Old   April 10, 2012, 08:34
What did you think about gnu m4 ? (
http://www.somogyibence.hu/documents...ckMesh_m4.html)
Old   April 10, 2012, 11:16
Assistant Moderator
Bernhard Gschaider
Sincerely hate it since I had to configure a sendmail-server. But I'm a man of many prejudices, so don't take my word.
Seriously: I think the main purpose of M4 is generating text files, not analyzing them. So it might be just the opposite of what you're looking for
Old   April 11, 2012, 02:17
Ok, thanks for your response.
Old   April 11, 2012, 03:51
Have you an example of BlockMesh script ? (Example of your script wrote with PyFoam)
Old   April 11, 2012, 16:02
Assistant Moderator
Bernhard Gschaider
Have a look at slide 42ff of http://web.student.chalmers.se/group...amAdvanced.pdf
I'm planing to add a more sophisticated templating-mechanism to later versions of PyFoam
Old   August 6, 2012, 06:55
Samuele Z
samiam1000 is on a distinguished road
Dear All,
pardon the question, but I think that this does not work.
In fact I have my launch.sh file which is the following:
'#!/bin/bash'
foamJob -p buoyantPimpleFoam;
reconstructPar;
cd ../1DegNew/;
mapFields -consistent ../1DegStartNew -sourceTime 100;
decomposePar;
buoyantPimpleDyMFoam_MS;
sed -i 's/1/2/' system/controlDict;
sed -i 's/2/3/' system/controlDict;
sed -i 's/3/4/' system/controlDict;
sed -i 's/4/5/' system/controlDict;
sed -i 's/5/6/' system/controlDict;
The problem is that the reconstructPar starts before the foamJob -p buoyantPimpleFoam is ended.
Any idea about that?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   August 6, 2012, 07:05
Pablo Higuera
Phicau is on a distinguished road
Hi
foamJob sends the solving process to the background and redirects its output to a log file, hence your following commands get to start as soon as the case starts.
Phicau is offline   Reply With Quote
Old   August 6, 2012, 07:48
Samuele Z
Dear Pablo,
thanks for answering.
I know that it is as you say, i.e. that foamJob solves in BG.. What I would like to know is if it is possible to launch all the commands that I give in BG on a server, executing them one after the other.
Thanks a lot,
Samuele
Old   August 6, 2012, 07:54
Pablo Higuera
Hi
it is very easy:
mpirun -np 8 buoyantPimpleFoam -parallel > log
where you just have to change the number of processors.
Regards
Old   August 6, 2012, 08:02
Samuele Z
If I give the command you suggested (i.e. mpirun -np 8 buoyantPimpleFoam -parallel > log), I'll launch the program in foreground and when I close the terminal where I am running it, the execution stops.
Let me try to explain what I wanna do: maybe you can help me.
I am performing some simulations on a server. I connect via ssh, from my laptop.
The point is that if I am working in serial, I can give
buoyantPimpleFoam > log
and then
ctrl z + bg
and then
disown
With mpirun, this syntax doesn't work, hence I user foamJob.
What should I do, to you?
Thanks a lot,
Samuele
Old   August 6, 2012, 17:55
Assistant Moderator
Bernhard Gschaider
and then
ctrl z + bg
and then
disown
Thanks a lot,
Samuele
Use the nohup command before mpirun. This makes it ignore the "death" of the shell
Old   August 7, 2012, 07:59
Samuele Z
If I understood well, I can write a launch.sh file like this:
'#!/bin/bash'
nohup foamJob -p buoyantPimpleFoam;
reconstructPar;
cd ../1DegNew/;
decomposePar;
Is that correct?
Thanks a lot,
Samuele
Execution problems in dsmcFOAM turanc OpenFOAM Running, Solving & CFD 3 April 10, 2017 12:58
Execution termination vidhya CFX 2 April 6, 2011 07:40
How to automate geometry, mesh and case setup using starccm+ jwillie2000 STAR-CCM+ 3 January 26, 2011 11:13
Measuring an Execution Time - f90 su Main CFD Forum 11 July 4, 2008 07:21
Background execution on UNIX systems law FLUENT 1 January 3, 2006 10:53
