[swak4Foam] questions about groovyBC
Old   December 14, 2012, 04:18
Default questions about groovyBC
immortality's Avatar
Ehsan
immortality is on a distinguished road
1)have totalPressure and totalTemperature been defined in groovyBC?
2)have it been assigned a piecewise function for having discrete values at different times in a discontinue manner?such that we can say for example since t0 until t1 velocity is such and such and since t1 till t2 such and such.
immortality is offline   Reply With Quote
Old   December 14, 2012, 04:45
Assistant Moderator
Bernhard Gschaider
In the library groovyStandardBCs there is a boundary condition groovyTotalPressure that allows setting the totalPresseure from an expression. t serves as an example on how to "groovify" standard boundary conditions. Same would be possible for totalTemperature but I currently have no intention to do this (but I'd accept contributions)
You can use the "a ? b : c"-operator which means "if a is true take b else take c". Or a timeline with two values very close to the jump
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 14, 2012, 10:07
Ehsan
thank you.it helps me a lot.
how can it be used exactly.where is the example you have mentioned?a clear example is appreciated.
How totaltemperature could be used then?
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] some questions about neibours of patches in groovyBC immortality OpenFOAM Community Contributions 7 March 3, 2013 11:38
[swak4Foam] Two questions about groovyBC immortality OpenFOAM Community Contributions 3 December 4, 2012 18:42
