How to set and read time-dependent source terms
Old   September 16, 2012, 13:19
Default How to set and read time-dependent source terms
Dean Meyer
DeanM is on a distinguished road
Dear Foamers,
I would like to read a time-dependent source term, which can be defined by a function in a file in the case directory and read from the solver itself.
So far I managed to set the source term using funkySetFields, but only as initial condition. My approach is the following: In createFields.H the field of the mass source is defined as follows:
        volScalarField massSource
        IOobject
            "massSource",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
        mesh
The equation to solve looks like
    fvScalarMatrix rhoEqn
      fvm::ddt(rho)
    + some terms
    == massSource
    rhoEqn.solve();
Finally the user should be able to define "massSource" with a mathematical expression as function of time and space in a file in the case directory. I tried to do it with funkySetFields, it works well for time 0, but I need it for all times. Example:
    massSource
        field massS;
        expression    "sin(pi*time())*(pos().x+pos().y"; //arbitrary function
        //condition    "...";
In conclusion: How can I define and read time-dependent source terms from the case directory?
Thank you for any ideas.
D.
DeanM is offline   Reply With Quote
Old   September 18, 2012, 05:33
shakil ahmmed
ahmmed04 is on a distinguished road
you can use the source term as a boundary condition, in that case you can easily use groovyBC.Or if you can access to the 'internalField' when creating source object, you might be able to do this.
ahmmed04 is offline   Reply With Quote
Old   September 20, 2012, 11:14
David Gaden
marupio is on a distinguished road
You could also use the equationReader extension. I'm working on a paper that will demonstrate this exact idea using it.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   September 24, 2012, 17:37
Assistant Moderator
Bernhard Gschaider
Originally Posted by DeanM View Post
Dear Foamers,
        IOobject
            "massSource",
            runTime.timeName(),
            mesh,
            IOobject::NO_WRITE
        mesh
      fvm::ddt(rho)
    + some terms
    == massSource
    rhoEqn.solve();
    massSource
        field massS;
        //condition    "...";
D.
In addition to the two other solutions given (equationReader and groovyBC) you can search the forum for expressionSource which comes with swak4Foam and does what you want (I've explained the usage in one of those threads ... you'll find it)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
How to read field files from the two different time directories fumiya OpenFOAM 1 August 1, 2021 06:58
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
contribution of convective source in total source? Antony Phoenics 4 July 30, 2008 05:15
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
