multi region problem in developing a new solver |
September 21, 2015, 00:54 |
nemo
Rep Power: 11 |
Hello,Foamers.
I am using the openfoam 2.4.0, and trying to write a new solver which is similar to chtMultiRegionFoam , here are my problems. First, I need to solve equations in the entire domain both in the fluid part and solid part, and I want this equation to be discretized into only one matrix A, in which the interface between fluid and solid need not to be treated as boundary. Second, solve the equations in the fluid part. Some calculated result in the first step needed to be transferred to this step as the energy source, but only in the fluid part . How to implement this? Can anyone give me some advice? Thanks a lot. |
May 17, 2016, 07:28 |
#2 | |
Karelke Yu
Rep Power: 11 |
I am facing the same problem. have you got a method to do this? |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Suggestions for a multi region conjugate heat transfer problem | maddalena | OpenFOAM | 14 | September 4, 2013 18:03 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
