[swak4Foam] Running funkySetFields
Old   November 13, 2008, 02:51
Default Running funkySetFields
Sara Schairer
sara is on a distinguished road
Hi
Probably a rather simple problem, but I still need some help. I have OpenFOAM 1.5. I downloaded funkySetFields which worked alright, but when I type the command "funkySetFields" just to see if it works I get: command not found.
Why's that?
I downloaded the directory into the /utilities/preProcessing directory. Do I have to put it somewhere else or is there just a step missing?
Cheers, Sara
sara is offline   Reply With Quote
Old   November 13, 2008, 04:53
Default Hi Sara Just a small questi
jaswi is on a distinguished road
Hi Sara
Just a small question before we go into details :
Did you compile it :-)
Kind Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   November 13, 2008, 18:53
Default Ehm, nope, I didn't. Because I
Sara Schairer
Ehm, nope, I didn't. Because I didn't know I have to. As a matter of fact I also don't know how to do it.. could you please tell me?
Thanks so much, Sara
Old   November 14, 2008, 00:34
Default Ok I got it. Thanks ;)
Sara Schairer
Ok
I got it. Thanks ;)
Old   November 14, 2008, 01:59
Default Hi Now funkySetFields is comp
Sara Schairer
Hi
Now funkySetFields is compiled and should be ok. However I still have some problems. I tried to run funkySetFields. I wanted to set gamma to 1 in a certain area on the inlet of my geometry. I'm using interFoam. I think I did everything as explained in the wiki. But apparently something is wrong because I get these error messages:
schairer@schairer-desktop:~/OpenFOAM/schairer-.5/run_execute/geometrieI_interFoam_tests1$ funkySetFields . geometrieI_interFoam_tests1 -time 0 -field gamma -expression 1 -condition "pos().x = 0 && pos().y >= 0.049 && pos().y <=>= 0.049 && pos().z <= 0.051"
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Usage: funkySetFields [-create] [-noZero] [-field <field>] [-condition <logical>] [-case dir] [-parallel] [-expression <expression>] [-keepPatches] [-dimension <dimension>] [-latestTime] [-valuePatches <list>] [-debugParser] [-time time] [-help] [-doc] [-srcDoc]
Wrong number of arguments, expected 0 found 2
FOAM exiting
Hope someone can help me figure this out.
Cheers, Sara
Old   November 14, 2008, 02:34
Default Hi Sara Good Morning Y
Hi Sara
Good Morning
You are using OpenFOAM 1.5.
It does not require to specify <root> <case>
Try your expression like this :
funkySetFields -time 0 -field gamma -expression 1 -condition "pos().x = 0 && pos().y >= 0.049 && pos().y <=>= 0.049 && pos().z <= 0.051"
and it shall work.
Hope that works else write back
Kind Regards
Jaswi
Old   October 3, 2012, 09:05
Sagun Tripathi
Sagun is on a distinguished road
Hello Sara,
I'm facing the same problem: command not found.
How did you compile it?
Thanks,
Sagun
Sagun is offline   Reply With Quote
Old   October 3, 2012, 09:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by Sagun View Post
Hello Sara,
Thanks,
Sagun
Compilation is described on the Wiki-page (depends on the version you're using - standalone or swak. But in both cases the process consists of one command)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 3, 2012, 09:43
Sagun Tripathi
I'm using OpenFoam version 2.1.1 on Linux 11.10. and so I installed swak4Foam instead of the traditional funkySetFields. Unfortunately, I don't seem to be able to find the compilation step on the page http://openfoamwiki.net/index.php/Contrib/swak4Foam
Maybe its something very obvious and I'm missing it on account of my very limited knowledge of OpenFOAM and Linux.
Another general question: What is meant by the directory of sources?
I have swak4Foam installed in my opt/openfoam2011/src directory. Is that what the author is referring to?
Thanks,
Sagun
Old   October 3, 2012, 09:56
Assistant Moderator
Bernhard Gschaider
How about point 2: Building (http://openfoamwiki.net/index.php/Co...4Foam#Building)
The director you downloaded. In your case probably opt/openfoam2011/src/swak4Foam
Old   October 3, 2012, 10:08
Sagun Tripathi
Thank you so much for your help but I'm still getting the same error: command not found.
I'm trying to implement funkySetFields using a funkysetFieldsDict file in the system folder.
Here is how the file looks like:
FoamFile
version 2.0;
format ascii;
class dictionary;
object funkySetFieldsDict;
expressions
InitialProfileVelocity
field U;
variables "u_f=0.949;z0=0.1;K=0.41;zground=184.557;";
expression "vector(0,1,0)*(u_f/K)*log((pos().z-zground+z0)/z0)";
keepPatches 1; //keep the boundary conditions that were set before
Is there something wrong with the approach I have adopted to implement funkySetFields?
Regards,
Sagun
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 09:01
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 02:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 19:07
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS JMosiezny OpenFOAM Installation 15 December 9, 2017 08:20
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 04:56
