simple doubt grad function
Old   September 14, 2012, 12:53
Default simple doubt grad function
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi Foamers,
my doubt is very simple. I am writing derived boundary condition for a scalar T. My project is related to flow of suspensions through channels. In my case for a scalar T at upper and bottom boundaries i need to apply zero surface normal flux boundary condition. When i applied this zero flux in my governing equation i got an expression for the dT/dy.
For scalarField T the governing equation is
solve
fvm::div(phi, T)
+ fvm::laplacian(0.62*1.82*pow(a,2)*g*pow(T,2)*pow(0 .68-T,-1), T)
+ fvm::laplacian(0.41*pow(a,2)*g*T, T)
- fvc::laplacian(0.41*pow(a,2)*T*T, g)
where g=local Strain rate
=mag(symm(fvc::grad(U)))
After applying zero surface normal flux, i got
dT/dy=pow(T, 2)*gm/(T*mag(symm(fvc::grad(U))*(1+T*2.75*pow(0.68-T, -1)))
To write this i have chosen tractionDisplacement boundary in solidDisplacementFoam. Based on that i written my code. Every thing is ok but in my derived boundary condition i used grad(U). When i compiled this derived BC the error like "no matching function for call to ‘grad(const Foam::vectorField&)" is coming.
Which header file i need to include please suggest me. Or any other easy way to write this BC.
Thanks
Regards
Mallikarjuna
mmkr825 is offline   Reply With Quote
Old   September 28, 2012, 14:25
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I believe the fvc::grad operator only works on geometricFields. If you're operating on a boundary you might have to manually calculate your zeroGradient condition which would be a function of the patch internal values and the deltaX from the patch face to the internal cell center. I'll see if I can dig up another BC that does something similar. Posting your BC code where the compiler threw the bug would also be more helpful than posting the code that compiled ok.
kmooney is offline   Reply With Quote
Old   September 28, 2012, 14:28
kmooney's Avatar
Kyle Mooney
Wouldn't the 'slip' boundary condition give you the zero normal flux condition you're looking for?
If you you don't need to write any new code.
Old   September 28, 2012, 14:39
Hi Kmoony,
Thanks for reply. I want to know what slip BC is able to do. Please suggest me any tutorial useful to understand the slip BC.
Thanks
Regards
Mallikarjuna
Old   September 28, 2012, 14:49
kmooney's Avatar
Kyle Mooney
I believe, physically, slip means there is no shear stress at the wall. It creates a no penentration, zero-tangential gradient condition. Just google around, you'll be able to figure it out in detail.
Old   September 28, 2012, 15:04
Hi kmoony,
Thanks for your advice i will go according to your suggestion.
I have one more doubt, not relevant to the present title of the thread. I am doing my PG project on flow of suspended particles through wavy channel (sinusoidal wave), of infinite length. First i created one full cycle, i need to extend this geometry (one full cycle) into infinite number depending on length of the channel. I studied periodic BC is suitable for it. Please give me some information about periodic BC, what actually it do.
Thanks
Regards
Mallikarjuna
Old   September 28, 2012, 15:14
kmooney's Avatar
Kyle Mooney
I'm not very experienced with period BC's in foam. Sorry I can't help.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
[OpenFOAM] LibvtkFoamso fred ParaView 2 November 18, 2005 19:01
Please help about the VTKFoam liugx212 OpenFOAM Running, Solving & CFD 0 November 18, 2005 18:27
