twoPhaseEulerFoam
Old   October 24, 2012, 08:20
Default twoPhaseEulerFoam - surface tension and wall adhesion
Michal
majkl is on a distinguished road
I'm using twoPhaseEulerFoam in OpenFoam-2.1.0 The calculation is going without surface tension and adhesion. Is it possible to implement this effects to this solver in some easy way?
Well, there is multiPhaseEulerFoam assuming surface tension and adhesion but only with LES turbulunce model.
Thanks for reply.
Regards,
Michal
Last edited by majkl; October 30, 2012 at 04:00. Reason: change the title to be more specific
majkl is offline   Reply With Quote
ubuntu twoPhaseEulerFoam seems to have 'bugs' freemankofi OpenFOAM 2 August 21, 2011 04:26
Something wrong in UEqns.H within twoPhaseEulerFoam cheng1988sjtu OpenFOAM 2 June 24, 2011 10:48
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 16:24
Stratified flow using twoPhaseEulerFoam karthik1414 OpenFOAM 4 May 4, 2011 05:12
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 hemph OpenFOAM 3 December 5, 2009 04:19
