lookup alpha1 from boundary patch
Like Tree3Likes
  • 1 Post By kmooney
  • 2 Post By michielm
Old   October 18, 2012, 04:56
Default lookup alpha1 from boundary patch
Michiel
michielm is on a distinguished road
I am trying to read the value of alpha1 in the boundary cells to apply it in a boundary condition, but until now I am unsuccesful. I have tried two different routes, both resulting in compilation errors.
The first thing I tried was to acces the mesh and extract alpha1 from it like this
const fvMesh& mesh = patch().boundaryMesh().mesh();
const volScalarField& alpha1 = mesh.lookupObject<volScalarField>("alpha1");
but this resulted in this massive error message
CAHCoxVoinovAngleFvPatchScalarField.C: In member function ‘virtual Foam::tmp<Foam::Field<double> > Foam::CAHCoxVoinovAngleFvPatchScalarField::theta(const Foam::fvPatchVectorField&, const Foam::fvsPatchVectorField&) const’:
CAHCoxVoinovAngleFvPatchScalarField.C:145: warning: unused variable ‘alpha1’
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C: In member function ‘const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]’:
CAHCoxVoinovAngleFvPatchScalarField.C:146:   instantiated from here
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:104: error: cannot dynamic_cast ‘iter.Foam::HashTable<T, Key, Hash>::const_iterator::operator() [with T = Foam::regIOobject*, Key = Foam::word, Hash = Foam::string::hash]()’ (of type ‘class Foam::regIOobject* const’) to type ‘const struct Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*’ (target is not pointer or reference to complete type)
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:111: error: incomplete type ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’ used in nested name specifier
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:128: error: incomplete type ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’ used in nested name specifier
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/typeInfo.H: In function ‘bool Foam::isA(const Type&) [with TestType = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Type = Foam::regIOobject]’:
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:40:   instantiated from ‘Foam::wordList Foam::objectRegistry::names() const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]’
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:128:   instantiated from ‘const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]’
/opt/apps/openfoam-2.1.0//OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/typeInfo.H:136: error: cannot dynamic_cast ‘(const Foam::regIOobject*)t’ (of type ‘const class Foam::regIOobject*’) to type ‘const struct Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*’ (target is not pointer or reference to complete type)
make: *** [Make/linux64GccDPOpt/CAHCoxVoinovAngleFvPatchScalarField.o] Error 1
Then a colleague suggested to use 'lookupPatchField' instead, like this:
const fvPatchField<scalar>& alpha1 = patch().lookupPatchField<volScalarField, scalar>("alpha1");
but alpha1 doesn't seem to exist in the patchField:
CAHCoxVoinovAngleFvPatchScalarField.C:150: error: no matching function for call to ‘Foam::fvPatch::lookupPatchField(const char [7]) const’
CAHCoxVoinovAngleFvPatchScalarField.C:149: warning: unused variable ‘alpha1’
Could someone please explain what is wrong in the two strategies above, or explain to me what the correct way of looking up alpha1 is?!
michielm is offline   Reply With Quote
Old   October 25, 2012, 11:43
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Something like this might work for you:
//get the patch ID number
label patchID = mesh.boundaryMesh().findPatchID("myPatchNameString");
//Lookup the desired alpha values on the patch you want
const fvPatchField<scalar>& alphaPatchField = alpha1.boundaryField()[patchID]
//local face value access
forAll(cPatch,faceI)
     scalar patchAlphaValue = alphaPatchField[faceI];
mm.abdollahzadeh likes this.
kmooney is offline   Reply With Quote
Old   October 26, 2012, 03:35
Michiel
Thanks for the response!
I have tried this, but I get the error that 'alpha1' is not declared in this scope.
So before I will be able to use your piece of code I first have to lookup alpha1 from somewhere and that is where it goes wrong.
Do you perhaps know how I can look up alpha1 from the mesh or the patch or something like it?!
Old   October 26, 2012, 04:13
Michiel
I just found out what the issue was: apparently alpha1 should not be read as a volScalarField but as a scalarField. I don't really understand why. But if i use this it works:
const scalarField& alpha1 = mesh.lookupObject<scalarField>("alpha1");
And then of course I still need to select the values on the patch, but that will work out with the method you describe.
Bernhard and Reptider like this.
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 01:54
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
