including third party GPU library in OpenFOAM
Old   March 13, 2012, 09:39
Question including third party GPU library in OpenFOAM
Spela I
spelai is on a distinguished road
this is a slightly convoluted question, but please bear with me.
We have incorporated the OpenMM GPU library (https://simtk.org/home/openmm) inside OpenFOAM and are using it to perform Molecular Dynamics force calculations on the GPU. The OpenMM is compiled as a shared library and included in the OpenFOAM MD solver.
OpenMM supports two GPU platforms: CUDA and OpenCL. CUDA is precompiled with a make compiler but OpenCL code gets compiled at runtime. As a consequence, CUDA code runs fine within OpenFOAM, but the OpenCL code crashes.
Unfortunately, we need the OpenCL and we suspect that the problem is due to the difference in compilers. The OpenMM example simulation code uses make and the OpenCL compiled this way works fine. However, when integrated in OpenFOAM, the solver is compiled with wmake and this seems to disagree with the OpenCL code. We have checked all the compiler options but to no avail.
Does anyone have a similar experience with integrating third-party libraries inside OpenFOAM? Would you be able to offer any insight?
Thanks,
Spela
spelai is offline   Reply With Quote
Old   March 13, 2012, 12:21
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
A few months ago I had integrated some CUDA into OF and had to achieve this as an extern function while compiling the CUDA separately and then including it in OF compilation. The project is at
http://code.google.com/p/cufflink-library/
the compile script you are interested is in
http://code.google.com/p/cufflink-li...k/nvccWmakeAll
and the example of the extern function in OF is
extern "C" void CFL_AinvPBiCGStab(cusp_equation_system *CES, OFSolverPerformance *OFSP);//extern function in CUDA that solves the equation system
in the file (http://code.google.com/p/cufflink-li...invPBiCGStab.C)
lastly, the definition of the extern function in CUDA is in
http://code.google.com/p/cufflink-li...nvPBiCGStab.cu
Hope that helps.
chegdan is offline   Reply With Quote
Old   March 13, 2012, 14:35
Spela I
Hi Dan,
thank you for your reply. I have found the same thing with CUDA - because it can be fully compiled externally, there seems to be no problem with including it in OF - the OF compiler does not need to recompile it while compiling the solver.
With the OpenCL, things seem to be different as you do not compile it externally, it gets compiled at runtime and it is here that I run into problems.
I'll have a look at your CUDA solution and see if I can get any ideas for how to tackle this.
Regards,
Spela
Old   November 2, 2012, 05:06
Default Have a look at clFoam
Klaus
klausb will become famous soon enough
there has been an OpenCl plugin for OpenFOAM - maybe that helps:
see: http://www.cfd-online.com/Forums/ope...very-soon.html
The OpenCL solver plugin : clFoam v0.1 come out for test.
Until now, clFoam single precision has been tested on ATI 5650M GPU and NVidia Tesla C2050. The speed is slightly slower than CPU on Tesla C2050 for 160000 cells of case: cavity 4 times steps (clPCG). (see profilingDatasheet.xls in profiling data/ for details)
The openCL solver is still promising, as it is a new tech and has great space to improve.
download link:
http://www.iesensor.com/download/clFoam_v0.1.zip
Quite a lot of work to do, any advice on improving the efficiency is appreciated. further, there must be some errors in the manual, DO leave me a email to correct them.
Thanks very much
Yours,
Qingfeng Xia
services@iesensor.com
Let me know how it works - I'm planning something similar.
Klaus
klausb is offline   Reply With Quote
gpu, molecular dynamics, openfoam, openmm
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Testing of OpenFOAM 1.4alpha Commenced OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 January 16, 2007 09:41
Testing of OpenFOAM 1.3alpha Commenced OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 February 7, 2006 07:31
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
