Add a scalarField type to the templated DataEntry class
Like Tree1Likes
  • 1 Post By manju819
Old   March 17, 2013, 15:52
Default Add a scalarField type to the templated DataEntry class
carowjp's Avatar
Jim Carow
carowjp is on a distinguished road
I would like to add a scalarField type to the DataEntry class such that an arbitrary number of scalars could be read in from CSV file. As it stands you can only get 1, 3, or 9 values in using scalar, vector, and tensor types. See code in /src/OpenFOAM/primitives/functions/DataEntry.
I wrote specializations for the scalarField nCSV<scalarField>::readValue and void Foam::nCSV<scalarField>::read() functions to allow specifying the start column and number of columns to read in from CSV.
The problem I facing at compile is that the scalarField, Foam:: pTraits<Foam::Field<double> >, does not have members 'nComponents' or 'zero', which of course the scalar, vector, and tensor types do.
Can anyone please give me some direction on how to fix this? I don't want to resort to using a VectorN type just to read data from file.
thanks,
Jim
carowjp is offline   Reply With Quote
Old   March 20, 2014, 05:20
Default Hiii carowjp
Manjunath Reddy
manju819 is on a distinguished road
If you want to read the scalarField
create a data file which has a scalarFields
Ex: file name PVTdata
which has a scalarField Bg
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object transportProperties;
Bg
9.342894e-02
4.567101e-02
3.013131e-02
2.219316e-02
1.746954e-02
1.427184e-02
1.205589e-02
1.041777e-02
9.144300e-03
8.184990e-03
7.393980e-03
6.737610e-03
6.221490e-03
5.789520e-03
5.452920e-03
5.172420e-03
4.925580e-03
4.712400e-03
4.532880e-03
4.370190e-03
and you can read this Field in create fields
using a IOdict
IOdictionary PVTdata
IOobject
"PVTdata",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
scalarField Bg
PVTdata.lookup("Bg")
I'm also tried to read data from CSV file but i dint get and I followed this. Hope this will help you
Regards
Manjunath
Bana likes this.
manju819 is offline   Reply With Quote
Old   May 24, 2016, 14:30
Mahdi Hosseinali
anishtain4 is on a distinguished road
If you want to read data from csv files use c++ approach. csv files are like text
anishtain4 is offline   Reply With Quote
csv files, dataentry, template errors
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
