time-varying internalField
Old   February 8, 2013, 02:50
Default time-varying internalField
Klio
klio is on a distinguished road
Hello!
I edited the chtMultiRegionFoam Solver so that it is possible to add a volumetric heat source to a region!
Now I want to implement a circuit where the heat source is switched on and off.
The problem is that the heat source entry has to be changed in the internalField because it is volumetric -> If i change the BC with timeVaryingMappedFixedValue of course it has no effects on the simulation !
Does anyone know how to fix that Problem?
Thanks! Klio
klio is offline   Reply With Quote
Old   February 9, 2013, 18:02
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Originally Posted by klio View Post
Hello!
Thanks! Klio
Hello Klio
If I understood correctly, a single scalar can be multiplied by the source term. This scalar can be your switch: 1 = lights on, 0 = lights off.
You can even make it a volScalarField and turn it on in some cells and off for others.
Hisham
Hisham is offline   Reply With Quote
Old   February 19, 2013, 03:32
Klio
oh! ok that sounds very simple! Thank you!
how can i implement the switch? is it possible to code it in the controlDict?
Old   February 19, 2013, 08:04
Hisham's Avatar
Hisham Elsafti
Sounds simple but to implement it you need to read the manual (chapter 3 in particular). Other tutorials on programming with OpenFOAM should also be helpful.
However, you need to slightly modify the code not an input for that in (e.g. controlDict) or so.
Hisham
Old   February 19, 2013, 22:17
Ivor Clifford
cliffoi is on a distinguished road
Hi Kilo,
My suggestion would be to use the expressionField or manipulateField functionObject in the swak4foam library.
http://openfoamwiki.net/index.php/Contrib/swak4Foam
Hope this helps
Ivor
cliffoi is offline   Reply With Quote
Old   April 12, 2013, 06:10
Marcus Letzel
letzel is on a distinguished road
Hi Kilo,
have you been successful with your solver? I would much appreciate if you could post your modified source code along with an example case that shows how to set up a time-dependent volumetric heat source.
Best regards,
Marcus
letzel is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
time varying boundary condition cfd-student CFX 0 April 15, 2008 08:31
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
