April 13, 2010, 04:35 |
Create particle clouds at runtime
Cedric Van Holsbeke
Rep Power: 16 |
The standard way of defining a kinematic cloud is by creating a createClouds.H file with following constructor:
Info<< "Constructing kinematicCloud1" << endl; basicKinematicCloud kinematicCloud1 ( "kinematicCloud1", rho, U, mu, g ); Code:
kinematicCloudNames kinematicCloud1 kinematicCloud2; Code:
Info<< "Reading kinematicCloudList\n" << endl; IOdictionary kinematicCloudList ( IOobject ( "kinematicCloudList", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); List<word> kinematicCloudNames(kinematicCloudList.lookup("kinematicCloudNames")); Code:
Map<kinematicCloud> kinematicClouds(kinematicCloudNames.size()); forAll(kinematicCloudNames, cloudI) { Info<< "Constructing " << kinematicCloudNames[cloudI] << endl; kinematicClouds.set(kinematicCloudNames[cloudI], new basicKinematicCloud ( kinematicCloudNames[cloudI], rho, U, mu, g ),true); } Code:
createClouds.H: In function ‘int main(int, char**)’: createClouds.H:29: fout: no matching function for call to ‘Foam::Map<Foam::kinematicCloud>::set(Foam::word&, Foam::basicKinematicCloud*, bool)’ /home/cedric/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/HashTable.C:256: note: kandidaten zijn: bool Foam::HashTable<T, Key, Hash>::set(const Key&, const T&, bool) [with T = Foam::kinematicCloud, Key = int, Hash = Foam::Hash<int>] /home/cedric/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/HashTableI.H:88: note: bool Foam::HashTable<T, Key, Hash>::set(const Key&, const T&) [with T = Foam::kinematicCloud, Key = int, Hash = Foam::Hash<int>] Is there a better system of grouping clouds? Or is there a better system to create clouds at runtime? |
April 15, 2010, 04:04 |
Cedric Van Holsbeke
Rep Power: 16 |
I am really unable to solve this problem. I have changed my code a bit
... Read in dictionary ... List<word> kinematicCloudNames(kinematicCloudList.lookup("kinematicCloudNames")); HashTable<kinematicCloud> kinematicClouds(kinematicCloudNames.size()); Code:
forAll(kinematicCloudNames, cloudI) { Info<< "Constructing " << kinematicCloudNames[cloudI] << endl; bool test = kinematicClouds.set(kinematicCloudNames[cloudI], new basicKinematicCloud ( kinematicCloudNames[cloudI], rho, U, mu, g )); } No matching function for call to ‘Foam::HashTable<Foam::kinematicCloud, Foam::word, Foam::string::hash>::set(Foam::word&, Foam::basicKinematicCloud*)’ /home/cedric/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/HashTable.C:256: note: candidates are: bool Foam::HashTable<T, Key, Hash>::set(const Key&, const T&, bool) [with T = Foam::kinematicCloud, Key = Foam::word, Hash = Foam::string::hash] However, as a test, when I try it with a HashTable of scalars, it works perfectly! Code:
HashTable<scalar> testTable(kinematicCloudNames.size()); forAll(kinematicCloudNames, cloudI) { bool test = testTable.set(kinematicCloudNames[cloudI], 1); } |
April 20, 2010, 06:41 |
Laurence R. McGlashan
Rep Power: 23 |
Instead of using List<>, use PtrList<>. I do a very similar thing to what you're trying to do in your code.
http://foam.sourceforge.net/doc/Doxy..._1PtrList.html
Laurence R. McGlashan :: Website |
April 20, 2010, 07:29 |
Cedric Van Holsbeke
Rep Power: 16 |
Thank you very much! It works perfectly now!
As a Java programmer, I am used to the fact that Lists and HashMaps can contain any Object, but in C++ this works a bit different For people having the same problem, the final code is: Code:
Info<< "Reading kinematicCloudList\n" << endl; IOdictionary kinematicCloudList ( IOobject ( "kinematicCloudList", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); List<word> kinematicCloudNames(kinematicCloudList.lookup("kinematicCloudNames")); PtrList<basicKinematicCloud> kinematicClouds(kinematicCloudNames.size()); forAll(kinematicCloudNames, cloudI) { Info<< "Constructing " << kinematicCloudNames[cloudI] << endl; kinematicClouds.set(cloudI, new basicKinematicCloud ( kinematicCloudNames[cloudI], rho, U, mu, g )); } Code:
forAll(kinematicClouds, cloudI) { Info<< "Evolving " << kinematicClouds[cloudI].name() << endl; kinematicClouds[cloudI].evolve(); } |
April 20, 2010, 07:57 |
Rep Power: 23 |
Also be careful, 'List' is not the STL version which is 'list', even though it probably has very similar functionality.
The problem you had was that 'set' was not a member function for 'List'. I'm always getting tripped up by these sort of things myself.
May 15, 2010, 11:59 |
Fiorenzo Ambrosino
Rep Power: 16 |
Hi guys, I also need to define kinematic clouds at runtime and I'm happy to have just found this useful topic! So very thank you both for this code.
In the posts however there is no reference to the necessary correction to the Ueqn.H file in which the contributions of individual clouds of momentum equation must be added (if I'm not wrong...). I'm trying to do this and I've written some code. I'm not a good C++ programmer so hope someone could help me. I've tried with this Ueqn.H: Code:
Foam::tmp<Foam::DimensionedField<Foam::vector, Foam::volMesh > > SU; forAll(kinematicClouds, cloudI) { SU = SU + kinematicClouds[cloudI].SU(); } fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + turbulence->divDevRhoReff(U) == // kinematicCloud1.SU() SU + rho.dimensionedInternalField()*g + flowDirection*DeltaPonL ); UEqn.relax(); if (momentumPredictor) { solve(UEqn == -fvc::grad(p)); } Thanks for the help. Fiorenzo |
March 7, 2013, 05:51 |
Jamal
Rep Power: 12 |
Dear OFrs
I am using OF 2.1.0 and looking for to write a simple macro to control writeInterval entitiy of controlDict file. For example if endTime is 10 and startTime is 0. I want to write every time directories like 1 2 3 4 5 and when runTime is greater than 5 then I want alternative directories 7 9 ..., I mean write internval should change from 1 to 2 as the time passes by 5. I am trying to use following line controlDict file but returned with errors writeInterval $(if(runTime.()>5) ? 2:1); please let me know how to use macro/directives properly in this regard. And in general is there documentation available for this topic. Thanks |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
