October 26, 2012, 14:16 |
modifying turbulentHeatFluxTemperature BC
Nikunj Raithatha
Rep Power: 13 |
Hello All!
I am trying to use the turbulentHeatFluxTemperature BC to use with buoyantBoussinesqPimpleFoam solver, by replacing all the 'alphaEff' in the BC with 'kappaEff'. however, while doing so, I am getting the following error: wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file heatFluxAFvPatchScalarField.C could not open file RASModel.H for source file heatFluxAFvPatchScalarField.C SOURCE=heatFluxAFvPatchScalarField.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/turbulenceModels -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/lnInclude -I/opt/openfoam211/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/turbulenceModel -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/heatFluxAFvPatchScalarField.o heatFluxAFvPatchScalarField.C:30:22: fatal error: RASModel.H: No such file or directory compilation terminated. make: *** [Make/linuxGccDPOpt/heatFluxAFvPatchScalarField.o] Error 1 my Make/options file looks like this: EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/transportModels LIB_LIBS = \ -lfiniteVolume Please help me with the same. Thanks, Nikunj. |
March 11, 2013, 20:25 |
#2 | |
Neilson Whit
Rep Power: 14 |
may be you solved the problem long time ago, but I also work on these issues nowadays... |
Modifying the laplacian operator | mlawson | OpenFOAM Running, Solving & CFD | 22 | July 16, 2018 04:56 |
modifying radial distribution function | ravindra | FLUENT | 2 | September 2, 2014 14:03 |
Modifying Gambit DBS file Created from MixSim 2 | gkennedy3 | ANSYS Meshing & Geometry | 0 | August 7, 2009 09:32 |
modifying Prepin File from command line | pgopalak | FLOW-3D | 1 | August 5, 2009 11:06 |
Modifying a mesh starting from case file | Ale | FLUENT | 2 | September 16, 2008 12:10 |
