Big Difference Between Serial run and Parallel run case
Old   March 19, 2013, 16:42
Default Big Difference Between Serial run and Parallel run case
yijin Mao
alundilong is on a distinguished road
Hi All,
I'm trying to solve a fluid dynamics problem with modified icoFoam (see attached). Found that different processor running give me very different results. Both solver and cases are attached, I'm looking for any suggestions on what happened. Thank you all in advanced!
I also run it on the latest OpenFOAM-2.2.0. Still got same problem.
alundilong is offline   Reply With Quote
Old   March 20, 2013, 15:52
yijin Mao
my bad! the solution diverged!
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
Big Difference Between serial run and parallel run case alundilong OpenFOAM Running, Solving & CFD 3 December 5, 2014 08:27
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 12:44
