defining constant transport property inside a turbulence model
Like Tree1Likes
  • 1 Post By PonchO
Old   May 2, 2013, 04:59
Default defining constant transport property inside a turbulence model
Christoph Kratzsch
PonchO is on a distinguished road
Hello Foamers,
i want to implement a turbulence model based on a k-epsilon-model for turbulent magnetohydrodynamics-flow.
Therfore i have to add additional dissipation terms in the epsilon-equation and in the k-equation.
These terms containing the density "rho" and the electrical conductivity "sigma".
Because that properties are constants in my incompressible case, i can't introduce them like it's done in the compressible turbulence-model.
So how can i introduce or address them inside my turbulence-model-files?
Best Regards,
Christoph
PonchO is offline   Reply With Quote
Old   June 19, 2013, 04:33
abe
ABE
abe is on a distinguished road
Hi Christoph,
Have you find a way to call rho inside turbulence model for incompressible case? if yes, please share.
ABE
abe is offline   Reply With Quote
Old   June 21, 2013, 06:48
Christoph Kratzsch
Originally Posted by abe View Post
Hi Christoph,
ABE
Hi abe,
after some trial and error i've found a solution.
In my .C-File i read the properties as follows:
//that part you should find in your turbulence-model-code
void kEpsilonZeta::correct()
    RASModel::correct();
    if (!turbulence_)
        return;
//Here the reading of the properties starts
    Info<< "\nReading transportProperties\n" << endl;
    IOdictionary transportProperties
        IOobject
            "transportProperties",
            runTime_.constant(),
            mesh_,
            IOobject::MUST_READ,
            IOobject::NO_WRITE,
            false
    dimensionedScalar nu
        transportProperties.lookup("nu")
    dimensionedScalar rho
        transportProperties.lookup("rho")
    // electromagnetic properties
    dimensionedScalar mu
        transportProperties.lookup("mu")
    dimensionedScalar sigma
        transportProperties.lookup("sigma")
    dimensionedScalar Cm
        transportProperties.lookup("Cm")
//Now the Solution of the turbulence transport equations follows
Hope that helps you too.
Best regards,
Christoph
abe likes this.
Old   June 21, 2013, 09:00
abe
ABE
Hi Christoph,
Thank you for sharing.
ABE
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 16:25
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 08:53
