null volScalarField
Old   May 28, 2013, 04:04
Default null volScalarField
Fabian E.
galap is on a distinguished road
Since OF2.2 there are a lot of changes to the thermophysicalModels. We are running libs here derived from basicThermo which requires now the specification of several virtual functions. I want to solve this by returning NULL pointer fields. Unfortunately I am not able to clearify how a NULL volScalarField can be returned. Does anyone know this?
Thanks in advance
galap is offline   Reply With Quote
Old   May 28, 2013, 05:55
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Fabian,
In such cases, where certain functions need implementation, but I know that they will never be used/does not make sense, I use the following in the source code:
notImplemented("<some string describing the issue>");
This will terminate the simulation with a FatalError, so cleaner than making the program work on NULL-pointers. With respect to the return type, then I simply ignore the warnings in the compilation, since the program will never reach
return <some object>;
Kind regards
Niels
ngj is offline   Reply With Quote
Old   May 30, 2013, 18:15
Thomas Boucheres
thomasArk47 is on a distinguished road
return volScalarField::null();
works fine (as well for volScalarField than for tmp<volScalarField>)
thomasArk47 is offline   Reply With Quote
Old   January 29, 2014, 04:19
Fabian E.
I met again this issue. The ::null() actually works, but I have problems to check, whether it is set or not.
What I am using now is: (schematic)
void request_data(autoPtr<volScalarField> data)
    if (..) { data.set(&<object-you-want-to-return>); }
    else { data.clear() }
    return data;
in main script:
autoPtr<volScalarField> data;
request_data(data);
if (data.valid()) { .... }
Maybe this helps someone
Old   January 29, 2014, 04:44
Fabian E.
Be aware that autoPtr takes over control of the prior associated pointer. Instead of autoPtr its better to use tmp. You can use the same syntax, just replace autoPtr with tmp. Instead the set function you have to use data = tmp<volScalarField>(&<object-you-want-to-return);
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
if-loop, volScalarField comparison volker OpenFOAM 7 March 6, 2020 20:03
Metis for OpenFOAM 2.1.0 Kaskade OpenFOAM Installation 8 May 31, 2014 01:20
dimensionedScalar + volScalarField is evaluated elementwisely ? tianyikillua OpenFOAM Programming & Development 1 March 30, 2012 03:12
momentum source in half-cylindrical null objects Noel Phoenics 1 December 16, 2008 05:51
