May 31, 2013, 05:19 |
interFoam solver
belkadi
Rep Power: 12 |
Dear Foamers,
I'm trying to test the example nozzleFlow2D by using the ineterFoam solver (multiphase). The example is provided from the OpenFOAM tutorial (tutorials/multiphase/interFoam/les/nozzleFlow2D). After running the blockMesh, I've run icoFoam to do the calculations, however I got the following error message : --> FOAM FATAL IO ERROR: keyword nu is undefined in dictionary "/home/abdelkrim/OpenFOAM/abdelkrim-2.2.0/run/tutorials/multiphase/interFoam/les/nozzleFlow2D/constant/transportProperties" file: /home/abdelkrim/OpenFOAM/abdelkrim-2.2.0/run/tutorials/multiphase/interFoam/les/nozzleFlow2D/constant/transportProperties from line 20 to line 69. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 402. FOAM exiting nu is well defined in transportproperties.dict Do you have any ideas Foamers ? Kind regards krimo |
May 31, 2013, 05:26 |
Cyprien
Rep Power: 18 |
launch interFoam instead of icoFoam
@++ Cyp |
May 31, 2013, 05:35 |
belkadi
Rep Power: 12 |
Yes ! it works
Many thanks for your fast answer Cyp. I'll try to apply it for my own application. Kind regards Krimo |
May 31, 2013, 05:40 |
Kie Hian
Rep Power: 14 |
I'm not familiar with nozzleFlow2D but the tutorial seems to be running fine on my installation (2.2.x). Just to check, why are you running icoFoam on a interFoam case?
May 31, 2013, 05:59 |
belkadi
Rep Power: 12 |
In fact, I'm a new user with OpenFOAM. I thought that icoFOAM is the command to use for all the solvers ! this is why I used the icoFOAM instead of interFoam.
Display Modes | |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM Running, Solving & CFD | 17 | December 3, 2014 20:41 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 19:06 |
atmosphere bc in dam brake case (interFoam solver) | Mike H. | OpenFOAM Running, Solving & CFD | 0 | July 30, 2009 07:35 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
Mistake in PISO loop for interFoam solver | kumar2 | OpenFOAM Running, Solving & CFD | 3 | June 30, 2006 19:26 |
