Troubles when create a new volScalarField in my own library
Old   June 19, 2013, 04:44
Default Troubles when create a new volScalarField in my own library
X Meng
mxylondon is on a distinguished road
Dear all,
I'm struggling to create a new volScalarField variable in my own function before compiling my own source code, the exactly same thing like pressure, density, viscosity, etc.
But failed again and again, any suggestion please?
mxylondon is offline   Reply With Quote
Old   June 19, 2013, 04:50
Nima Samkhaniani
nimasam is on a distinguished road
fail? your question is too vague, atleast post your error line
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 19, 2013, 05:18
X Meng
error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField()’
Old   June 19, 2013, 08:10
Nima Samkhaniani
would you mind!, add your pieces of code here too
Old   June 19, 2013, 10:48
Bernhard
Bernhard is on a distinguished road
Suggestion: copy existing code from a solver and rename the variables.
Bernhard is offline   Reply With Quote
Old   June 19, 2013, 12:26
X Meng
A very simple test, the header file (XXX.H) is:
#include "fvCFD.H"
#include "IOstream.H"
#include "messageStream.H"
namespace Foam
namespace Test
class Try
public:
volScalarField value1,value2;
static volScalarField newField( );
The implement file (XXX.C) is:
#include "XXX.H"
namespace Foam
namespace Test
volScalarField value1;
volScalarField Try::newField( );
volScalarField value2;
value2=value1;
return (value2);
To generate a new library, I have tried with some 'int' type functions and variables in this way, they can be compiled and work well to be called in a main program.
But when the variable type is 'volScalarField', did I miss something? Like other header files to include?
Old   June 20, 2013, 02:42
Bernhard
As far as I can see, you are trying to call a volScalarField constructor without any arguments. There is no such constructor, see: http://foam.sourceforge.net/docs/cpp/a00776.html , to construct a volScalarField, you need at least a mesh somewhere.
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? lzgwhy ANSYS Meshing & Geometry 5 May 18, 2017 17:10
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 11:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
