interPhaseChangeFoam source terms
Old   June 27, 2013, 16:58
Default interPhaseChangeFoam source terms
luftraudi is on a distinguished road
I tried to understand the implementation of the cavitation models using interPhaseChangeFoam in OpenFOAM. The (uncomplete) source terms for the volume fraction equation are stored in the field mDotAlpha in each model. Then the field vDotAlphal is computed in phaseChangeTwoPhaseMixture.C. This field is conform to the source term of the volume fraction transport equation except of the factor (1 - alphal) for the condensation term and alphal for vaporisation term. Then in alphaEqn.H vDotAlphal is used without the factors. I guess this is not correct.
Did I misunderstood something in the code?
Furhtermore, I am wondering about the fact, that in alphaEqn.H the condensation source term (vDotcAlphal) is used twice, as implicit source term (sp) and as explicit source term (su).
Thanks in advance,
Michel
luftraudi is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Source Terms in momentum Balance vidyaraja FLUENT 0 May 25, 2009 13:16
UDF - source terms Fred FLUENT 2 October 11, 2005 20:53
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
