error: Floating point exception
Old   June 27, 2013, 10:50
Default error: Floating point exception
suhas jain suresh
suhas jain is on a distinguished road
Hi everyone,
I am trying to implement level Set Method in OpenFoam, but I got this error in pEqn.H.
I have not changed anything in "pEqn.H" or related to that.
Any advice?
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at /opt/openfoam220/src/finiteVolume/lnInclude/fvMatrixSolve.C:81
at ~/OpenFOAM/suhas-2.2.0/applications/solvers/levelSetFoam/pEqn.H:37
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
in "/home/suhas/OpenFOAM/suhas-2.2.0/platforms/linux64GccDPOpt/bin/levelSetFoam"
Thanks,
Suhas Jain
Graduate student, Stanford University
suhas.jain2000@gmail.com
suhas jain is offline   Reply With Quote
Old   July 5, 2013, 04:33
Nicklas Linder
nlinder is on a distinguished road
I can recommend to build a OF-Version with debugging enabled. That helped me with the same kind of error
http://openfoamwiki.net/index.php/Ho...UG_-_libraries
your problem might be a division by zero, or infinity or a multiplication of fields of different size. I also thought the problem was in the pEqn.H but i turned out it was a lot earlier..
Greetings
Nicklas
nlinder is offline   Reply With Quote
Old   July 5, 2013, 04:57
suhas jain suresh
Hi Nicklas,
Thank you for the reply. I found out the error using nemiver. There was a mistake in defining Heaviside function which gave an error in pEqn.H. Now everything's working fine!!..
Thanks,
Suhas Jain
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) ArianeJasmin OpenFOAM Programming & Development 1 April 4, 2012 14:11
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
Flouting point exception twoPhaseEulerFoam - I set delta t cristina87 OpenFOAM 1 May 26, 2011 15:35
Cannot Open .sim (Floating Point Exception) trex930 STAR-CCM+ 1 July 30, 2010 06:51
