Adding a BC for pointPatchField/tetPolyPatchField
Old   July 1, 2013, 11:30
Default Adding a BC for pointPatchField/tetPolyPatchField
Hannes Kröger
hannes is on a distinguished road
I just came across some strange problem which I could not solve yet. Maybe someone has a hint for me:
I have created some user defined BC which I want to use in the "pointDisplacement" field of the fvMotionSolver as well as in the "motionU" field of the tetDecomposition motion solver. I therefore templated the class:
template
  template<class> class PatchField,
    class Mesh,
    class PointPatch,
  template<class>   class MatrixType
class FEMDisplacementPatchVectorField
    public FixedValuePointPatchField
        PatchField,
        Mesh,
        PointPatch,
        MatrixType,
        vector
Then I have instantiated the BC for the pointPatchField which works as expected:
typedef
FEMDisplacementPatchVectorField<pointPatchField, pointMesh, pointPatch, DummyMatrix>
FEMDisplacementPointPatchVectorField;
makePointPatchTypeField
    fixedValuePointPatchVectorField,
The same works also for the tetPolyPatchField (with either CELL_DECOMP or FACE_DECOMP defined):
typedef
FEMDisplacementPatchVectorField<tetPolyPatchField, tetPointMesh, tetPolyPatch, tetFemMatrix>
FEMDisplacementTetPolyPatchVectorField;
makePointPatchTypeField(tetPolyPatchVectorField, FEMDisplacementTetPolyPatchVectorField);
The strange thing is: if I compile with "FACE_DECOMP", everything seems ok i.e. I can select the BC in the "motionU" file. But if I compile with "CELL_DECOMP", the code compiles well, but I cannot select the BC in the field file. My BC class is then not contained in the selection table.
As far as I understand, there should be nothing changed in my code except than defining the appropriate preprocessor symbol. Or do I miss something?
Thanks for any hint.
Best regards, Hannes
hannes is offline   Reply With Quote
Old   July 17, 2013, 09:39
achyutan is on a distinguished road
Hi hannes,
case 1 : if you have compiled your new boundary condition under openfoam src, then you have to include that executable/ .so file in controlDict of your case.
case 2 : if not as mentioned above, i.e. if you have compiled your b.c separately, you have to recompile your solver by including the new bc file in its header and changing files and options appropriately.
from what i understand based on ur post, case 1 is the solution. hope this helps..
regards,
achyutan
achyutan is offline   Reply With Quote
Boundary condition setting for adding gravity in simpleFoam norkistar OpenFOAM Programming & Development 3 June 15, 2022 04:20
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Adding linear generation in InterFOAM voingiappone OpenFOAM Programming & Development 8 June 14, 2013 00:47
car Cd drops after adding inlet and outlet? wh88 FLUENT 0 October 19, 2011 13:23
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 17:16
